[CLOSED] Screen Replacement Cost?
Thread Status:
Not open for further replies.
  1. stephenlotus
    KitKat Jan 16, 2015
    stephenlotus , Jan 16, 2015 :
    not at all. It registers touch fine just like the original screen. Are you talking about your original screen or the replacement?
    Axara likes this.
  2. Axara
    Ice Cream Sandwich Jan 17, 2015
    Axara , Jan 17, 2015 :
    My original screen. It is a pain in the a** and a nightmare
  3. DrJMun
    KitKat Jan 17, 2015
    DrJMun , Jan 17, 2015 :
    From other threads it would appear that $200 to get it "fixed" by OnePlus (however it appears what actually happens is that they'll send you a refurbished phone... check your IMEI number).
    Under $100 to buy a replacement screen, and while it is possible you can do it yourself I dont think it's all that easy. Plus you run the risk of not getting a genuine screen.
  4. cedelutis
    Honeycomb Jan 17, 2015
    stephenlotus likes this.
  5. stephenlotus
    KitKat Jan 17, 2015
    stephenlotus , Jan 17, 2015 :
    are you thinking about replacing it just to fix the touch issue?
  6. Axara
    Ice Cream Sandwich Jan 20, 2015
    Axara , Jan 20, 2015 :
    Yes and no, I'm not so sure about it, because it is quite a picky surgery! Besides, I don't know if a new screen will do or I can fix it with my current screen but need to isolate it properly.
  7. stephenlotus
    KitKat Jan 21, 2015
    stephenlotus , Jan 21, 2015 :
    if it is for sure a hardware issue, replacing the screen would definitely work. I suggest maybe taking off the back cover and camera cover to check to see if the flex cables are properly connected to the logic/motherboard.
    Axara likes this.
  8. charbs06
    Eclair Mar 6, 2015
    charbs06 , Mar 6, 2015 :
    Hi Arron how did your new phone screen come out? I'm thinking about sending mine to opo. Did you factory reset before sending it to them and did they send you back your original phone or a refurbished one? Thanks
  9. Naveen Verma
    Honeycomb Aug 14, 2015
    Naveen Verma , Aug 14, 2015 :
    will my phone be still covered with warranty, if I changed the digitizer my self?
    And is there quality or any type of difference between original digitizer and one bought from external sources?
  10. urisaba
    Cupcake Aug 27, 2015
    urisaba , Aug 27, 2015 :
    Oneplus gives only 1 year warranty.... The real question is:
    Will they still fix my screen for the said service fee (147€) IF i open my opo to see if all cables are properly connected?
  11. mageoffaith
    Donut Aug 28, 2015
    mageoffaith , Aug 28, 2015 :
    Because Oneplus requires 5 replies to stop spam. Here's some spam so I can get my 5 replies to start an actual thread.
  12. psunnylfc1892
    Cupcake Jan 14, 2016
    psunnylfc1892 , Jan 14, 2016 :
    Hi there,
    So my screen broke yesterday and i contacted RRR and they say only the screen costs €102. Excluding labor fee and accessment fee. So the price is likely to rise for sure. You say your cost €147. The repair shop near me charges €149 but I guess its not genuine. Could you give me some advise what I should do?
    Thanks!
    Regards,
    Sunny Pradhan
  13. O1600466651711
    Cupcake Oct 3, 2020
    O1600466651711 , Oct 3, 2020 :
  14. O1600466651711
    Cupcake Oct 3, 2020
  15. O1600466651711
    Cupcake Oct 3, 2020
  16. O1600466651711
    Cupcake Oct 3, 2020
    Just found out about knock off screens did your phone come back fixed I just want my oneplus 8 to oneplus repair for new screen and I'm hoping it's a legit oled not lcd so did they give you a oled one??
  17. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator Oct 4, 2020
    Artemus. likes this.
