[CLOSED]Slider problem via OnePlus 8
Thread Status:
Not open for further replies.
  1. amitmoorjani1
    Cupcake Jul 21, 2021
    amitmoorjani1 , via OnePlus 8 , Jul 21, 2021 :
    My slider doesnt work on silent. It works only upto vibrate even if i slide it upto the limit to silent. Please update your software so that this problem will be solved.
  2. Aaron2017
    Lollipop Jul 21, 2021
    Best Answer
    Aaron2017 , Jul 21, 2021 :
    Have you tried cleaning out the alert slider with a wooden toothpick or non metallic object? There might be some dust or something interfering and often cleaning it is the solution.
    McJader and J4t1np4r3kh like this.
  3. amitmoorjani1
  4. amitmoorjani1
    yes but it didnt work.It is getting silent only in dnd.
  5. Aaron2017
    I don't mean to criticize your cleaning skills, just checking, but did you thoroughly pry in there with a toothpick? It can get pretty deep in there.
  6. amitmoorjani1
    it work now. thnx
    Aaron2017 likes this.
  7. Aaron2017
    Ah, good to hear. You're welcome.👍
  8. superplus
    Head Moderator Head Moderator Jul 21, 2021
    superplus , Jul 21, 2021 :
    Hi, as per the forums' Terms & Rules, I've merged your two threads on the same.
    Glad to hear @Aaron2017's helpful suggestion has helped you to resolve the issue, I'll close this thread as resolved. Any issues, feel free to PM: https://forums.oneplus.com/conversations/add?to=superplus
    McJader, J4t1np4r3kh and Aaron2017 like this.
