[Closed] small circle on top left of screen
Thread Status:
Not open for further replies.
  1. G_av_phani_hDzJ
    Cupcake Feb 18, 2019
  2. ngydat
    KitKat Feb 18, 2019
    ngydat , Feb 18, 2019 :
    Do you see it all the time ?
  3. Daan_Eekhofアニメ
    Jelly Bean Feb 18, 2019
    nishitcs94 likes this.
  4. G_av_phani_hDzJ
  5. G_av_phani_hDzJ
  6. FateSeal
    Donut Feb 18, 2019
    FateSeal , Feb 18, 2019 :
    Hello
    You are sure its not your wallpaper background ?
    Greetings from Fate :cool:
  7. Matt 80
    Lollipop Feb 18, 2019
  8. Cheetosdust
    Starting Point Expert Feb 18, 2019
    Cheetosdust , Feb 18, 2019 :
    Seems to me like it's burn in caused by PUBG.
    That circle aligns with the UI of the game.
    Do you play a lot of it?
    Kytharsis likes this.
  9. G_av_phani_hDzJ
    G_av_phani_hDzJ , Feb 18, 2019 :
    Yes, I play PUBG a lot.
  10. Cheetosdust
    Yeah, if you compare that circle with this picture of the UI:
    It aligns perfectly. So it seems like it is indeed burn in caused by the game.
  11. G_av_phani_hDzJ
    yes it alligns perfectly. but mine is 8 GB device. I play around 3-4 hrs a day. It shouldn't burn like this. I hope this will be covered under warranty
  12. SandeepNaik091
    Gingerbread Feb 18, 2019
    SandeepNaik091 , Feb 18, 2019 :
    the 8gb ram you are talking about has no connection with burn in issues. Burn in is because of the display ( it may happen even because of a wallpaper)
    Kytharsis and G_av_phani_hDzJ like this.
  13. G_av_phani_hDzJ
    my bad then. does this issue will be covered in warranty??
  14. SandeepNaik091
    May be , may be not. Depends on how much the care centre personal understands the problem. In most physical damage cases, it's always a no.
  15. FateSeal
    Donut Feb 18, 2019
    In case its burn in make a support tiket.
    I hope for you it is under warranty, but i don't know.
    Press both thumbs for you
  16. G_av_phani_hDzJ
    by keeping the full brightness, I can see Pubg's level 3 bag icon on that.[e]1f62d[/e]. PUBG ruined my mobile
  17. gubro
    KitKat Feb 18, 2019
    gubro , Feb 18, 2019 :
    No, it is not covered as it is user caused damage.
  18. J1550512006975
    J1550512006975 , Feb 18, 2019 :
    it's not all about the game or some huge usage of mobile. my mobile also got the same circle at the same place where u have got just go to the one plus store with your bill they will replace it with a free of cost....
    G_av_phani_hDzJ and Shield98 like this.
  19. G_av_phani_hDzJ
    Cupcake Feb 20, 2019
    G_av_phani_hDzJ , Feb 20, 2019 :
    Yes. Just came out of service center with my screen replaced for free
    An.I.Am likes this.
  20. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Feb 20, 2019
    KeepTransisting , Feb 20, 2019 :
    You might consider playing a little less PUBG if you're playing it enough to cause burn in. It will happen again otherwise
    G_av_phani_hDzJ and Kytharsis like this.
