[CLOSED][SOLVED]Is there a difference between the charging cables?
Thread Status:
Not open for further replies.
  1. xMcMx
    Ice Cream Sandwich May 24, 2019
    xMcMx , May 24, 2019 :
    Hey,
    I recently bought a 7 Pro after using a 3T.
    The charging cable that's included in the box looks exactly the same as my old one but without the "Dash" branding.
    Is there another difference or is it basically the same cable just different power bricks?
    cheers
  2. Tobikage
    Nougat May 24, 2019
    Tobikage , May 24, 2019 :
    Yes.
    Its not hard to find simple answers if you attempt to search.
    Maybe read.....
  3. xMcMx
    Tobikage likes this.
  4. superplus
    Head Moderator Head Moderator May 24, 2019
    superplus , May 24, 2019 :
    Exactly this:
    Thanks for the answer @Tobikage.
    In accordance with the Terms & Rules, please try to find an existing thread, rather than create your own. I will close this thread as answered. Please have a look at the following FAQ thread for the OP7 series, it might contain more useful information to any other questions you might have:
    https://forums.oneplus.com/threads/oneplus-7-series-user-manual-questions-answers.1035365/
