[CLOSED][SOLVED]TWRP unale to mount storage. Help!!
Thread Status:
Not open for further replies.
  1. Ample_Heart
    Gingerbread Jun 2, 2017
    Ample_Heart , Jun 2, 2017 :
    I just wipe everything including internal storage, now I want to install new rom but my device is not showing storage on my PC. so I'm uanble to move new rom to internal storage. Please help. No rom is installed, internal storage is also empty. please tell me what to do now?
    feernando997 likes this.
  2. Sun90
    Starting Point Expert Community Expert Jun 2, 2017
    Sun90 , Jun 2, 2017 :
    You shouldn't wipe system, as it will remove the installed ROM for you.
    A data wipe is all you needed from twrp.
    Can you boot into recovery.
  3. Bartnl
    Lollipop Jun 2, 2017
    Bartnl , Jun 2, 2017 :
    Start up in TWRP
    Go to wipe>format data and type yes.
    After formatting you will be able to access the internal storage again.
    See the rooting part at: https://forums.oneplus.net/threads/...wrp-root-nandroid-efs-backup-and-more.475142/
    Sun90 likes this.
  4. Ample_Heart
    yep i can boot into twrp recovery only. NO os is present, nothing else.
  5. Sun90
    Ample_Heart likes this.
  6. Ample_Heart
  7. Sun90
    What are the options you get in TWRP recovery for installation.
  8. Bartnl
    No.
    In TWRP he can't access the internal storage with his PC. Meaning he can't transfer anything to his phone. (like the OS zip file to flash the OS)
    A format will mount the internal storage again and makes it accessible again.
    Sun90 likes this.
  9. Bartnl
  10. Bartnl
    Have also a look at this:
    Natje049, mobincbabu and Sun90 like this.
  11. Ample_Heart
  12. Ample_Heart
    Twrp showing all options. But my internal storage is empty and I cannot transfer any data to Internal Storage because unable to mount internal storage.
  13. Bartnl
    Having the same problem at this very moment (flashing clean Beta 8).
    Solution: restart TWRP (in TWRP: reboot>>recovery)
    After restart TWRP: Wipe>Format data>yes>
    Now your internal storage is formatted and you can access it from a PC.
    ErynOP, alfredo.f, Katakuna and 3 others like this.
  14. Ample_Heart
    SoniaB likes this.
  15. SoniaB
    Head Moderator; Community Hero 2020 Head Moderator Jun 2, 2017
    SoniaB , Jun 2, 2017 :
    Closed as per your request [​IMG]
    NaterTots and Ample_Heart like this.
