[Closed] Still battery drainage issues on 7.1.1 Nougat on the 3T??
Thread Status:
Not open for further replies.
  1. G_Manzoor_Ahmed_xkqv
    Eclair Jun 3, 2017
    G_Manzoor_Ahmed_xkqv , Jun 3, 2017 :
    Hi guys,
    I want to upgrade to 7.1.1 but so many people have reported fast battery drainage issues, is this still the case on the 3T or has this been resolved?
    And finally is it worth upgrading to 7.1.1 or is it better to stay on Android 6?
  2. SJBoss
    Lollipop Jun 3, 2017
    SJBoss , Jun 3, 2017 :
    just go for it... if you aren't facing it on 6, hopefully you wont be facing it on 7
    and IMHO you should try OB 8 its very optimized
    your welcome
  3. F_Michal_Doblej_dBkm
    Ice Cream Sandwich Jun 3, 2017
    F_Michal_Doblej_dBkm , Jun 3, 2017 :
    i have tried the stable OOS and also the Open Beta also tried LineAge OS ... with the OOS and Open Beta no mather what i do i cant get more then 4 hour SOT, even when batt drain over night is like 6% in 7 hours only LineAge OS give me almoust 5 hours SOT but dosent have Dash so i have downgraded back to MM rom where i can get 5-6 Hour SOT no problem and the batt drain during the night is like 2-3% in 7 hours.....next i will try resurection remix and also woulkd like to try the Dirty unicorns ROM to se if i get more then 4-5 hours of SOT as for now MM Roms are better then N when it comes to SOT at least for my OP3
  4. Aravinth_Kavya
    Cupcake Jun 3, 2017
    perryfig and IhaveOneM8 like this.
  5. quaddropop
    Honeycomb Jun 3, 2017
    quaddropop , Jun 3, 2017 :
    Not necessarily. Although I'm tired of the neverending discussions I must admit that my battery life has been superior on 6.x.x. Upgrading to Nougat was a big downstep concerning battery life.
  6. perryfig
    Froyo Jun 3, 2017
  7. F_Michal_Doblej_dBkm
    hahaha yeah cupcake suggestion based on what ???? on the 5 to 10 battery prob threads raised everyday
    quaddropop likes this.
  8. G_Manzoor_Ahmed_xkqv
    Eclair Jun 3, 2017
    Thankyou, I have no issues with 6, I have decided not to upgrade and will only consider once maybe and hopefully Android O is released. Many thanks
  9. G_Manzoor_Ahmed_xkqv
    Eclair Jun 3, 2017
    Thanks I shall try ROMs if the release of or Android O itself disappoints.
  10. G_Manzoor_Ahmed_xkqv
    Eclair Jun 3, 2017
    I mean if OP do not release Android O I will most likely try ROMs as a last resort but tbh Android 6 is running really well
  11. G_Kapur_Milan_bqMj
    Cupcake Jun 3, 2017
  12. F_Michal_Doblej_dBkm
    well you are welcome i thing it is worth to try the newest roms and you will see if they are ok for your usage, apps colection ,need atc .... you can still downgrade by cleanflasing the rom and bootloader if you are not sattisfied with the new ROMs.....this is what i totaly love on OP phones you wont void the warranty by unlocking the bootloader and flashing other ROMs
  13. G_Manzoor_Ahmed_xkqv
    Eclair Jun 3, 2017
    Really? I won't void the warranty? where does it state this?
  14. F_Shamik_Patel_eLQW
    F_Shamik_Patel_eLQW , Jun 3, 2017 :
    Issue solved.... Hope thread will close shortly
    @SoniaB @camohan
    F_Michal_Doblej_dBkm likes this.
  15. F_Michal_Doblej_dBkm
  16. Fathaah Ansar
    Gingerbread Jun 3, 2017
    Fathaah Ansar , Jun 3, 2017 :
    I used to constantly get a min of 5-6 hrs of SoT on my 3T when I was on Open Beta 7 with ElementX kernel. And before you ask, I didn't underclock. Doing that could yield around 7-8 hrs of SoT.
  17. Maxmxir
    Maxmxir , Jun 3, 2017 :
    7.1.3 and OOS 4.1.3, 3-4h Sot in 4G
    In WiFi 5h, if you have the choice Stay In Android 6.0
  18. Funk Wizard
    Moderator Moderator Jun 3, 2017
