3
[Closed]System lag via OnePlus 7
Thread Status:
Not open for further replies.
  1. SandeshChinchapur
    Ice Cream Sandwich Jul 5, 2020
    SandeshChinchapur , via OnePlus 7 , Jul 5, 2020 :
    Currently on 10.3.3 with my OnePlus 7, I'm facing lagging issue. This is the first time I've faced such issue.. the notifications remain stuck half way when swiped to clear. They stay half way for a second and then clear. Also the 'Android 10 back gestures' are lagging.. the back animation stays half a second and then goes. The animation is lagging .. am I the only one facing this?
    please solve this ASAP.
    ASAP768, Cherry_2.0 and Ajaygupta3129 like this.
  2. Artemus.
    Nougat Jul 5, 2020
    Artemus. , Jul 5, 2020 :
    When is the last time you formatted?
    Batman360 likes this.
  3. SandeshChinchapur
  4. Artemus.
    Nougat Jul 5, 2020
    Well, there's your problem. Back up your stuff, upload it to Google Drive, factory reset, download your stuff after setup. App data is saved server-side so all you need to do is log back into your services.
  5. SandeshChinchapur
    Why do I have to do that? I never had this issue but post 10.3.3 it's horrible. It has something to do with the update, and does OnePlus suggest factory reset for their OS bugs?
    9494473322 likes this.
  6. Artemus.
    Nougat Jul 5, 2020
    Actually, yes, they do.
  7. SandeshChinchapur
  8. Artemus.
    Nougat Jul 5, 2020
    It's basic maintenance. If you take your phone in for repairs, they'll do the same thing. It's the easiest thing to do, no need to make a mountain out of it. Takes quite literally, what, 10 minutes to back up, reset, set it back up and redownload your apps.
  9. G_Tanner_Nalley_ynDG
    Cupcake Jul 5, 2020
    G_Tanner_Nalley_ynDG , Jul 5, 2020 :
    I am having a similar issue out of the blue. I doubt it has to do with the OS being bloated or whatever as multiple people on the forum have had the same issue recently.
  10. I1591009231978
    Cupcake Jul 5, 2020
  11. Artemus.
    Nougat Jul 5, 2020
    Same question to you two: when did you last format?
  12. G_Tanner_Nalley_ynDG
    Cupcake Jul 5, 2020
  13. Ujjwalprashar
    Gingerbread Jul 5, 2020
    Ujjwalprashar , via OnePlus 7 , Jul 5, 2020 :
    Frequent factory resets should be a solution to proper functioning of a 500,600$ mobile phones.....
  14. Ujjwalprashar
  15. Cherry_2.0
    Donut Jul 5, 2020
    Cherry_2.0 , via OnePlus 7 , Jul 5, 2020 :
    Even I am facing the same issue. After this update , my phone is lagging and back button , home button , navigation bar are too slow for responding. Don't know when this will get fixed ☹️☹️[I didn't even format or connected my device to any external source]
  16. SandeshChinchapur
  17. I1591009231978
    Cupcake Jul 5, 2020
    I1591009231978 , Jul 5, 2020 :
    If i have to format the $642 phone frequently for smooth functioning, then I should have sticked with my nokia 6.1 plus 😐
    SandeshChinchapur likes this.
  18. Cervantes
    Lollipop Moderator Jul 5, 2020
    Artemus. likes this.
