[Closed]Too much heating while gaming and charging via OnePlus 7T
Thread Status:
Not open for further replies.
  1. shirish46
    Donut Jun 14, 2021
    shirish46 , via OnePlus 7T , Jun 14, 2021 :
    Now you totally stop beta update please fix this bugs as soon as possible 🥺 cant gaming like that .. and dont say play in cooler , we cant play cooler every time
    ChinmaySati likes this.
  2. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Jun 14, 2021
    Liehjan , Jun 14, 2021 :
    I will not say play in cooler, instead I will say don't charge and play at the same time :p
    And if you do, you could try a power adapter will lower Wattage. That will help with the heat.
    shirish46 and Tobikage like this.
  3. Cervantes
    Moderator Moderator Jun 14, 2021
    Cervantes , Jun 14, 2021 :
    Hello
    Please, Use the search engine before opening a new thread: Search
    Question answered
    You can use: My Feedback, from the community app to report a bug
    use the battery thread for battery and heating problems: Here
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    Install cpuz: check temperature
    Read the forum rules: Rules
    Thread closed
    shirish46 and Liehjan like this.
