140
[CLOSED] Try Hydrogen OS Now!!!
Thread Status:
Not open for further replies.
  1. oneplusone2024
    Eclair Jul 31, 2015
  2. Deactivated User
    Jul 31, 2015
    natheux likes this.
  3. krazy
    Honeycomb Jul 31, 2015
  4. Yudmud
    Froyo Jul 31, 2015
    Yudmud , Jul 31, 2015 :
    Wait, isn't this supposed to be a open beta and activation codes are not needed? Which one have you installed, the one that @dnle71 provided?
  5. xgen
    Eclair Jul 31, 2015
    xgen , Jul 31, 2015 :
    Activation code is: 0528-0728-0528-0728
    I flash the zip @dnle71 provided us and i lost my IMEI. I was on ColorOS, be careful guys.
  6. Misal6666
    Misal6666 , Jul 31, 2015 :
    which recovery do you recommend? and we can always edit the updater script right?
  7. natheux
    natheux , Jul 31, 2015 :
    I recommend the latest TWRP.
    For your second question, maybe no, 'cause when I've update the original v7 of H²OS to v8 via OTA (not modified by NisseCool), I didn't need to change something in the updater-script (if I remember well)
    Misal6666 likes this.
  8. Kujarka
    Gingerbread Jul 31, 2015
    natheux likes this.
  9. Vorbis Mogni
    Cupcake Jul 31, 2015
    Vorbis Mogni , Jul 31, 2015 :
    Found this tidbit of poorly translated info which relates to the IMEI issue. Could someone get a better translation up from here so we know what we are dealing with? This is what google gave me.
    "personal recommendation should not downgrade [white] Remember, if you are downgrading ROM package will advance into the phone memory card can be a brush, ROM package proposal Select colorOS2.0 and oxygen OS, after all, this is the official version of two complete systems package, if the underlying incomplete ROM, may result in the loss of IMEI code)"
  10. pradeepsmehra
    Ice Cream Sandwich Jul 31, 2015
    pradeepsmehra , Jul 31, 2015 :
    Buddy.. Update script has no role in ur OTA.. Its build.prob which u should not change to get update... Removing assert from Update script cant result u any OTA fail..
  11. xgen
    Eclair Jul 31, 2015
  12. gaster
    Moderator Moderator Jul 31, 2015
    gaster , Jul 31, 2015 :
    Ok buddy. Thanks and let us know if you don't mind
  13. Yudmud
    Froyo Jul 31, 2015
  14. xgen
    Eclair Jul 31, 2015
    Yeah, flashing cm12S via fastboot
  15. oneplusone2024
    Eclair Jul 31, 2015
  16. Deactivated User
    Jul 31, 2015
  17. arvindautar
    Eclair Jul 31, 2015
    arvindautar , Jul 31, 2015 :
    scratch my comment
    Deactivated User likes this.
  18. Deactivated User
    Jul 31, 2015
    natheux likes this.
  19. Yaznas
  20. xgen
    Eclair Jul 31, 2015
    Finally i have installed succesfully.
    We must flash the recovery i post before via fastboot using .bat
    After we must do wipe data/factory reset and cache
    Finally apply update and flash the rom
