664
CLUB INDIA Reborn
  1. prakashsr91
    Ice Cream Sandwich Dec 10, 2014
    prakashsr91 , Dec 10, 2014 :
    After I replied, I thought you'll tell this only...
    Nope, no Catwoman Moderator... Joker Moderator is fine with me :p :D
    GoonerBoy and OALEXANDER like this.
  2. hetalk
    Dec 10, 2014
    hetalk , Dec 10, 2014 :
    1) strange. They turn off for me. I remember someone reporting such issue. Search the thread.
    2) I dont use onscreen navbars. But it's a known thing with a working workaround. You can find it on the ROM thread.
    I'm using opo original flip case and it surely is awesome.
    I think I saw an option to do that in cm11s. I think it's at the same place where someone posted that large icons option didn't work.
    Funk Wizard and prtkchaudhary like this.
  3. harshalg
    harshalg , Dec 10, 2014 :
    ok....i have found a temp workaround the first issue...if the buttons backlight is off while locking the phone, then they will stay off as long as the phone is locked (so i've set the illumination timeout to 1 second)....but as i said, this is just a temp solution....also, no solution in sight for the second issue....i'll just browse the corresponding xda forum for any permanent solutions regarding this
    EDIT: btw, there has been daily updates to the version of CM12....so if i want to install any of those updates on my phone now, it will be with a dirty flash, right?
    lefttobleed and Deactivated User like this.
  4. ParamK.
    Moderator Moderator Dec 10, 2014
    ParamK. , Dec 10, 2014 :
    Go to settings>storage , press the three dots button in upper right corner and selrct the media type device option
    Rohitpurii likes this.
  5. neeraj.09
    Jelly Bean Dec 10, 2014
    GoonerBoy and nirmalnathaniel like this.
  6. hetalk
    Dec 10, 2014
    Yes, dirty flash is good, unless clean flashing required is stated by the developer for that particular build.
    I am sure I read about the disabiling hardware key workaround on that thread. I'll look for it later today and let you know. Again I don't use onscreen ones as I like to utilize the full screen.
    lefttobleed likes this.
  7. mahelinks
    Gingerbread Dec 10, 2014
  8. harshalg
  9. haris_wani
    haris_wani , Dec 10, 2014 :
    but then no body will take u seriously!!! lol
  10. hetalk
    Dec 10, 2014
  11. kishorkitchu
    Donut Dec 10, 2014
    Tanishq Singla likes this.
  12. Tanishq Singla
    Cupcake Dec 10, 2014
  13. harshalg
    but android specifically discourages from modifying the generic key layout files over here
  14. Tanishq Singla
  15. Funk Wizard
    Funk Wizard , Dec 10, 2014 :
    Its available in Trebuchet settings
  16. hetalk
    Dec 10, 2014
    And we don't care what they say. Lol
  17. Funk Wizard
    Seek your invites elsewhere, this thread is closed for invite sharing
    nirmalnathaniel, Dushie and neeraj.09 like this.
  18. Tanishq Singla
    Tanishq Singla , Dec 10, 2014 :
    I am sorry i didnt know that
  19. neeraj.09
  20. harshalg
    i figured that would be your reply :p:p....i'll think about modifying the generic file only after i'm confident that i wont screw it up....till then, my phone stays buggy (btw, the bugs are nothing major....nothing that hinders my day-to-day usage)
