Same here....I ignored it but as you said if I want to keep call on hold or ivrs or want to mute it ....I will be dead
@Funk Wizard where were you all this tym...
one more my battery doesn't show any stats....which all apps contribute to what % of battery drain....!! Edit :now its showing...jus after charging for 5 mins it was balnk (edit closed)
Also how to unmount USB OTG ? Every time I force remove system notification shows unmount before removing to save data ....but I couldn't find any options to do that !!
15 mins in this forum ....on 3G I lost 5% battery...I am on stock kernal ....this is not normal....heating is more with this one...
Again thanks .....I will try your tips one by one...
What is this modem required for.. ??
Ping me...
Who is in the middle?Vikas?
