667
CM 11S 30O, OTA Slowly Rolling Out!
Thread Status:
Not open for further replies.
  1. mydragoon Ice Cream Sandwich Aug 21, 2014
  2. picklu Eclair Aug 21, 2014
    picklu, Aug 21, 2014 :
    How to enable automatic unlock feature in flip cover? I can't enable! :-(
  3. Usincsx Froyo Aug 21, 2014
    Usincsx, Aug 21, 2014 :
    I have the flip cover too, the automatic unlock feature worked out of the box. Did not have to do anything. I am running stock Cyanogen 25R.
    The site says "*Requires CyanogenMod 11 version XNPH22R or higher"
    spanish33 and picklu like this.
  4. picklu Eclair Aug 21, 2014
    Mine also 25R and using Nillkin flip cover! Are you using other flip cover or their original cover? Is that an issue? Really confused :-(
  5. BarryM Cupcake Aug 21, 2014
    BarryM, Aug 21, 2014 :
    Really happy to see timely updates for this phone, makes me want it even more.
  6. j08rebelo Gingerbread Aug 22, 2014
    j08rebelo, Aug 22, 2014 :
    it works with the original flip cover. don't need to make any configuration.
  7. bcskunk Froyo Aug 22, 2014
    bcskunk, Aug 22, 2014 :
    still havent received the 30O OTA while others are getting the 33 already - wtf
    ExTanvy likes this.
  8. avsroy Gingerbread Aug 22, 2014
    avsroy, Aug 22, 2014 :
    Only the original flip cover will have the auto wake/lock feature.
    There is a work around for other flip case users, install Gravity Screen On/Off app by Plexnor that is available on Google Play Store. That app has the same functionality and more and is free. It does use a bit of the battery, but not much.
    It also works without a flip cover, say when you put the phone in your pocket for example. Lots of options and it really works.
  9. kevm66 Gingerbread Aug 22, 2014
    kevm66, Aug 22, 2014 :
    Good news guys:
    https://forums.oneplus.net/threads/cm-11s-xnph33r-ota-security-update.94409/#post-4609849
  10. Nuno Amaro Gingerbread Aug 22, 2014
  11. bartje01 Gingerbread Aug 22, 2014
    bartje01, Aug 22, 2014 :
    I have the systemUI.apk error when I try to update to 30O, how can I fix this?
  12. picklu Eclair Aug 22, 2014
    picklu, Aug 22, 2014 :
    Thanks for the info! I have installed it... Ok I will try those feature! :)
  13. mikaela Froyo Aug 22, 2014
    mikaela, Aug 22, 2014 :
    Me too! :( And if I try to sideload it, I get an error: assert failed: apply_patch_check("/system/framework/apache-xml.jar", "44e4ac783bd6fd314bc8be982d44e972da0abe1f", "eab54a24a53732ddccbe83ff3e8e690fa253ced6")
  14. Ivan O'Neill Eclair Aug 22, 2014
    Ivan O'Neill, Aug 22, 2014 :
    Nice to see that you're taking care of the problems that have arisen!
  15. filledk Gingerbread Aug 22, 2014
    filledk, Aug 22, 2014 :
    me 2
    wtf
  16. filledk Gingerbread Aug 22, 2014
    is there any way to install/flash the 30O update through TWRP without loosing data?
  17. gggofn Cupcake Aug 23, 2014
    gggofn, Aug 23, 2014 :
    Sorry for the delay forget to set a email reminder for this forum...
    The Clear Image mode is really good! Clearer, lesser noise, even smaller file size, good for both day & night shot. But too bad it's a separate shot mode so can't work with HDR mode.
    I can't tell any difference from EXIF but the image resolution (4160x3120) slightly different from other modes (4208x3120).
  18. Art Froyo Aug 23, 2014
    Art, Aug 23, 2014 :
    Got the 33 update on a brand new device and capacitive buttons are dark as hell. Is this software or hardware issue? Anyone know
  19. daryxdj Gingerbread Aug 23, 2014
  20. mikaela Froyo Aug 23, 2014
    mikaela, Aug 23, 2014 :
    @filledk any luck with this? I wonder what could have modified that apache file... Hmmmmm. And why others have that prob too? Maybe a somewhat common app caused the mod?
    I didn't get the notification to update to 30O OTA yet. You?
