484
CM 11S 44S OTA is out!
Thread Status:
Not open for further replies.
  1. bhtalia1
    Froyo Nov 8, 2014
    rahjr42 likes this.
  2. rahjr42
    Donut Nov 8, 2014
    rahjr42 , Nov 8, 2014 :
    So we can see what issues early adopters run into.
    Seff likes this.
  3. willielc
    Gingerbread Nov 8, 2014
  4. Ericksco
    Ericksco , Nov 8, 2014 :
    Awesome avatar! :)
  5. JayBerry99
    Honeycomb Nov 8, 2014
    JayBerry99 , Nov 8, 2014 :
    Do we have to install it manually or will I get a push notification to install it through an app / system / automatic update?
  6. oneplusdoc
    Jelly Bean Nov 8, 2014
    oneplusdoc , Nov 8, 2014 :
    OTA update has not shown up as yet here in uk...38R showed up after 24 hours in my case.
  7. xbrav
    Cupcake Nov 8, 2014
    willielc likes this.
  8. Aaroneloy21
  9. xbrav
    Cupcake Nov 8, 2014
    xbrav , Nov 8, 2014 :
    Try a manual check under Settings > About Phone > System Updates. You can force a manual check there.
  10. Vithz
    Vithz , Nov 8, 2014 :
    in 44s.. I think battery backup isn't much!! addressing to the developers.. fix the bug.. reduced battery backup!!
  11. willielc
  12. Neymarinho
    Froyo Nov 8, 2014
    Neymarinho , Nov 8, 2014 :
    Anyone else having wifi problems after updating. I can only connect to wifi for 10-20 seconds then I have no connection. I either have to reboot or turn off the wifi and back on again and even then it's the same story.
  13. iCrayon
    Froyo Nov 8, 2014
  14. xbrav
    Cupcake Nov 8, 2014
    Mine has been on wifi since the OTA update finished. I haven't had any disconnects.
    Did you encrypt your phone? My colleague had issues with wifi due to the phone being encrypted. I believe 44S has a fix for that.
  15. patstar5
    patstar5 , Nov 8, 2014 :
    Where do I get a modified flashable Ota zip? The regular Ota won't work since I modified system files
  16. Neymarinho
    Froyo Nov 8, 2014
    Nope. Didn't encrypt my phone.
  17. JakobRosenberg
    Ice Cream Sandwich Nov 8, 2014
  18. gbajpai
  19. keessonnema
    KitKat Nov 8, 2014
  20. sayem
    Eclair Nov 8, 2014
    sayem , Nov 8, 2014 :
    Hi Guys,
    I'm rooted & using TWRP recovery. While doing that I saw many posts saying we'll be able to get OTA updates. So please confirm me guys.
    Thanks in advance.
