484
CM 11S 44S OTA is out!
Thread Status:
Not open for further replies.
  1. dagerm89
    Froyo Nov 13, 2014
    dagerm89 , Nov 13, 2014 :
    Just passing it on, I had to reference a good amount of stuff to get 44s and get my phone rerooted after I screwed it up haha
  2. OneRNDPHLive
    Ice Cream Sandwich Nov 13, 2014
    Flyologist likes this.
  3. carburano
    Jelly Bean Nov 13, 2014
    OneRNDPHLive likes this.
  4. Flyologist
    Flyologist , Nov 13, 2014 :
    Exactlly :)
  5. OneRNDPHLive
    OneRNDPHLive , Nov 13, 2014 :
    That's all I'm saying. But I wouldn't mind having a bit of icing on that cake (i.e. feeling secure in the OTA) with a side of ice cream (i.e. actually having no issues installing the OTA) and potato chips (i.e. no post OTA issues) to seal the deal. ;)
    carburano likes this.
  6. dagerm89
    Froyo Nov 13, 2014
    If it helps, everything is buttery smooth on 44s for me. Only issue was when I messed up my root access, but that was my own doing, not CM.
  7. OneRNDPHLive
  8. bmaz121
    Froyo Nov 13, 2014
  9. OneRNDPHLive
    Thank you for sharing. :)
  10. ksamgeorge
    Honeycomb Nov 13, 2014
  11. ksamgeorge
  12. dagerm89
    Froyo Nov 13, 2014
    Since you mentioned that you use TWRP here's what you have to do to manually flash 44s. Can't really answer the other questions because I have no clue what's going on with your failed update.
    1) Download that zip file to your phone. That is the file needed for the 44s update.
    2) Turn off the phone, then boot into recovery by holding power + down volume
    3) Install the file you downloaded from the link I gave you.
    4) reboot
  13. ksamgeorge
    ksamgeorge , Nov 13, 2014 :
    ha ha ha
  14. AaronSchneider
  15. bmaz121
    Froyo Nov 13, 2014
    bmaz121 , Nov 13, 2014 :
    By nothing I mean after reboot I still have the phone exactly like it was with 38r. no problems just no 44 update. so please answer the previous question. Where did the file go?
  16. akhilseth
    Froyo Nov 13, 2014
    akhilseth , Nov 13, 2014 :
    I got mine this afternoon, screens attached.
  17. dagerm89
    Froyo Nov 13, 2014
  18. dagerm89
    Froyo Nov 13, 2014
    I told you that I don't know what happened with your failed update or where the file went. However, if you download the zip file through the link I gave you then it'll probably be in your Download folder.
  19. bmaz121
    Froyo Nov 13, 2014
    Wifi probably needs to be reconfigured after a system install. Readd your AP SSID. and password.
  20. bmaz121
    Froyo Nov 13, 2014
    Sorry, I'm not getting your updated meesages here as fast as I write them. Thanks for the help. Later!
