Cm 12 Nightly sudden death bug?
  1. chopchopw
    Ice Cream Sandwich Apr 12, 2015
    chopchopw , Apr 12, 2015 :
    So I was playing with my phone yesterday. Locked it and then tried to unlock it again right to check the time as per usual. This time however, the screen remained black. I tried again and it looked like the phone turned itself off. This is with 80+ battery left. Tried to hold the power button 10 sec to restart, no go. Tried to go into download or recovery mode, still no go. Was going to try again in my car with the usb cord connected but 10 minutes later it turned itself back on after 10 seconds of pressing the power button before i got in mu car. It worked fine after that. Do you guys think this is simply a software bug or could something be wrong with my phone?
    Thanks
  2. t4ww4b
    Jelly Bean Apr 12, 2015
    t4ww4b , Apr 12, 2015 :
    I had this thrice with 3 different builds! Soft reboot didn't work but at some point it went to fastboot (power + volume up and down).
    Ceasedd likes this.
  3. prashant sahni
  4. chopchopw
    dam did it reoccur randomly or just after every flash?
  5. t4ww4b
    It happens when you have your phone in standby-mode for a long time. Anyway, I have installed a custom kernel (AK V137) maybe that's the cause of it.
    Ceasedd likes this.
  6. chopchopw
    Thanks. standby as in screen off or just on for an extended period of time without reboot?
  7. t4ww4b
    I had it when the Screen was off and I hadn't used the phone for approximately a hour or more.
    chopchopw likes this.
  8. DaxNagtegaal
    Marshmallow Apr 12, 2015
    AntMunny, Ceasedd and chopchopw like this.
  9. chopchopw
    thanks. def hope this is not a hardware problem. I havent really found a phone i would like to buy to replace this at the moment.
  10. DaxNagtegaal
    DaxNagtegaal , Apr 12, 2015 :
    this problem is present in just about every rom on this phone so yeah it probably is a hardware problem but there is a workaround so it isn't a big deal.
    Turning that option I mentioned off fixes it.
  11. maansg
    Honeycomb Apr 12, 2015
    maansg , Apr 12, 2015 :
    Thanks you probably saved me in the future from getting a heart attack.;):)
    DaxNagtegaal likes this.
  12. t4ww4b
    No that's not true. I can confirm that I'm using CM12 Nightlies for almost a month and I've turned off that feature since the beginning. The problem still occurs.
  13. rrainwater
    rrainwater , Apr 12, 2015 :
    Yeah its not a proximity sensor bug. It sounds more like a kernel issue.
  14. t4ww4b
    This is what I thought...
  15. P0wnd
    Froyo Apr 12, 2015
    P0wnd , Apr 12, 2015 :
    So it's just me who doesn't have any problems with cm12 nighty?
  16. Theviko
    Eclair May 16, 2015
    Theviko , May 16, 2015 :
    Same here. Today happened to me twice in 3 hours. Just 1 minut after last use and I need to reboot
