7
CM 12S Issues - India Region
  1. pramone
    Froyo Apr 20, 2015
    pramone , Apr 20, 2015 :
    @pmsuga
    I'm not sure if I can share external links here.... I think the author of the blogpost (that helped me go back to 11s from 12s) himself had posted this in some other thread in this forum.... but the links were removed.....
    Hence:
    >> Please google for How to Return Back to CM11s from CM12
    >> click on the first result you get
    >> follow the instructions there
    You need to 'Unlock your Bootloader' for which you can use the same tool that is mentioned in that blogpost....
    Am just a NOOB and I really do not know what that tool does..... but it worked for me.... so please follow instructions on that blogpost at your own risk........
    I had installed 12S manually on my OPO and am now back to 11S.....
  2. FoG
    Donut Apr 20, 2015
  3. 8275276201
    Froyo Apr 20, 2015
    8275276201 , Apr 20, 2015 :
    factory reset n install the update
    kingsathurthi likes this.
  4. rajeshk
    Honeycomb Apr 22, 2015
    rajeshk , Apr 22, 2015 :
    Turn per app profiles on, it may solve your heating issues.
    Setting -> Performance -> Enable per app profiles
  5. kingsathurthi
    Donut Apr 22, 2015
    kingsathurthi , Apr 22, 2015 :
    Factory reset can bring my OPO into CM11S???
  6. manthancar
    Cupcake Apr 23, 2015
    manthancar , Apr 23, 2015 :
    Yeah it worked on the same day after I wrote the post.
    Thanks anyway.
  7. vinojohn
    Honeycomb Apr 23, 2015
  8. Abdur Rahman
    Donut Apr 25, 2015
    Abdur Rahman , Apr 25, 2015 :
    Thank
    Thanks Bro...
  9. junaid_s
    Eclair Apr 26, 2015
    junaid_s , Apr 26, 2015 :
    I am facing 3 major issues on my OPO with Cyanogen OS: 12.0-YNG1TAS17L which are impacting greatly......
    1) Doesnt vibrate when flip cover closed
    2) Auto Brightness is buggy, sometime automatically dims/brightens even if the external light is constant
    3) on CM11, when you touch the Data connection in Quick Settings Panel, it would automatically activate/deactivate data connection in one touch, Now in CM12, we need to touch on Data connections tile > Turn on /off cellular data > click Done. (3 touches to activate/deactivate).... Previous was better.. is it a bug or by design... (if be design please change back to earlier method)
    Can we have an estimated time for these issues to be fixed ???
  10. nameissantosh
    Gingerbread May 3, 2015
    nameissantosh , May 3, 2015 :
    Screen display is switched off need to on the display before attending the call this happens when the phone is in pocket
  11. malleswarasastry
    Honeycomb May 4, 2015
    malleswarasastry , May 4, 2015 :
    You can add it to the drawer single toggle button for on and off.. But yes for change in network mode (3g to 2g) you need more clicks..
  12. arbaazsha
    Cupcake May 4, 2015
    arbaazsha , May 4, 2015 :
    Guys, recently upgraded to cm12s. But I have a problem with Icons in Themes.
    I was randomly trying different themes and changed to 'Modern' Theme. After this whichever themes I change to, the Icons remain the 'Modern' theme icons. I tried reseting the theme and applying "Hexo', 'System' and so on. Restarted the phone each time after updating the theme.
    Also I deleted the modern theme from my phone but the problem persists.
    Is there any solution apart from Factory reset?
    Please help.
  13. jideshc
    Froyo May 4, 2015
  14. Thameem Ansari
    Cupcake May 5, 2015
  15. nameissantosh
    Gingerbread May 5, 2015
  16. shiv.emf
    Ice Cream Sandwich May 5, 2015
    shiv.emf , May 5, 2015 :
    how to clear cache from stock recovery?
  17. kishpatil
    Cupcake May 5, 2015
    kishpatil , May 5, 2015 :
    Need help guys, after updating my fon to 12, my contacts are missing n cannot get it through Google account. Please help me...
  18. isiddharthm
    Donut May 14, 2015
  19. nadeempatel
    Froyo May 15, 2015
    nadeempatel , May 15, 2015 :
    Install cpu cooler and check wat processes are used in back ground... Once u kno the process go to privacy...select the process... And disable auto run..awake..
    Dont do for system ui and radio services though...i am using cm 12 nightlies.. And hv done that..post that my battery backup is 14-16hrs...i watch movies 2.5hrs and watsapp almost all day with 30min of calling...
