9
cm-13.1-znh2kas254 OTA for OPO is out!
  1. greendragon
    Ice Cream Sandwich Jul 6, 2016
    #41
    raaomoka likes this.
  2. andyinthailand
    Jelly Bean Jul 6, 2016
    andyinthailand , Jul 6, 2016 :
    I've installed it and so far it seems that my battery life is better and my phone isn't doing any random reboots like it did before!
    #42
    jamdutch, armmani2001 and go8soccer like this.
  3. Kerryn
    Cupcake Jul 6, 2016
    Kerryn , Jul 6, 2016 :
    I got notification of this update and downloaded via CM update checker, however when I try to install via TWRP I get updater process ended with error: 7.
    Any ideas?
    #43
  4. cosmic
    cosmic , Jul 6, 2016 :
    Incremental updates dont install via TWRP - you have to wait for the "full" image file to become available.
    #44
    RB_82 likes this.
  5. Kerryn
    Cupcake Jul 6, 2016
    OK, thanks. Won't waste any more time.
    Will it appear as an OTA update, eventually?
    #45
  6. varadparulekarofficial
    Gingerbread Jul 6, 2016
    #46
    castlefox and TForesto like this.
  7. varadparulekarofficial
    #47
  8. Jac_Q
    Jac_Q , Jul 6, 2016 :
    Thankfully they fixed that one.
    Although didn't happen too often, it was annoying that you had to turn off and turn on the display to answer the call.
    #48
  9. B92
    #49
    bahar_b, armmani2001 and jabo3500 like this.
  10. Jac_Q
    Why won't you install the CM recovery, update and flash TWRP again?
    Did it a minute ago and took about 2 minutes.
    #50
  11. tfae
    #51
    nickelodeon likes this.
  12. Kerryn
    Cupcake Jul 6, 2016
    #52
  13. Daniel1+1
    Daniel1+1 , Jul 6, 2016 :
    Manual update thru standard recovery. The delay in the launching dialer is fixed. Hoping over the next few charging cycle that the battery will last longer on this version. Screenshot_20160706-023101.png
    #53
  14. rsrohit
    Eclair Jul 6, 2016
    #54
  15. ninjasumit
    ninjasumit , Jul 6, 2016 :
    It was already fixed on ZNH2KAS1KN.
    #55
  16. Linzeed
    Cupcake Jul 6, 2016
    Linzeed , Jul 6, 2016 :
    This does not fix the roaming issue for Vodafone users in NZ.
    Have just made the painstaking process of restoring stock recovery and updating in the hope it would fix it but it doesn't.
    #56
  17. ofive
    ofive , Jul 6, 2016 :
    I installed the CM recovery through TWRP and tried to update the system but during process it failed. Dont know why. Any idea to help?
    #57
  18. evon
    evon , Jul 6, 2016 :
    It didn't for me in the previous update...and it's still malfunctioning in this update. I've cleared cache partition countless times.
    #58
  19. Linzeed
    Cupcake Jul 6, 2016
    Flash it through adb.
    Unless you are running a custom kernel as well?
    #59
  20. p2p
    Honeycomb Jul 6, 2016
    p2p , Jul 6, 2016 :
    Like the partner said, it was fixed in the last ota (ending in KN).
    Have you checked that is activated the option "check proximity sensor" in settings menu??
    Is something with your device or settings. Foe the rest of us is working fine time ago.
    #60
