35
CM11s 05Q issues thread
Are you experiencing issues with the latest update?
  1. Yes (OTA update)
    55.6%
  2. Yes (Manual flash .zip)
    13.5%
  3. No (OTA update)
    15.3%
  4. No (Manual flash .zip)
    5.5%
  5. Yes but not anymore
    1.3%
  6. Haven't updated yet.
    8.8%
  1. zdravke
    Gingerbread Feb 26, 2015
    venkatasiva08, Chriss29 and aris like this.
  2. visivakumar
    Froyo Feb 26, 2015
    visivakumar , Feb 26, 2015 :
    Did it work?
  3. Tricia24
    Ice Cream Sandwich Feb 26, 2015
    Tricia24 , Feb 26, 2015 :
    No. Its 2:30pm here, my phone has been on battery since 6:30am, with only 1h 50m screen on time, and I have 9% battery left. It'll be dead before 3pm.
    Interestingly, switching from dalvik to art runtime did seem to fix a few other unrelated minor glitches though.
  4. visivakumar
    Froyo Feb 26, 2015
    Hmm.. So that means that it is not really a solution and I was just lucky. It's just a bittersweet symphony, this life.
    As an experiment (if you are up for it), you could change it again to Dalvik and see if there is any improvement.
  5. amndk
    Eclair Feb 26, 2015
    amndk , Feb 26, 2015 :
    I don't know whether anyone else faces this problem (a quick search through this forum doesn't turn up anything). I can't think of anything that could've caused it but the new OTA update. Whenever I try to share an image through the notification bar, the phone reboots. :|
    aris likes this.
  6. andreaskoelsch
    Cupcake Feb 26, 2015
    andreaskoelsch , Feb 26, 2015 :
    Can someone please send me a Trebuchet apk? I deleted it an now I cannot update to 05Q. When trying to update it says: "assert failed: apply_patch_check("/system/priv-app/Trebuchet.apk", hashcode, hashcode"). I assume it could work if someone could send me a Trebuchet.apk to install.
  7. ElChanfle
    Froyo Feb 27, 2015
    ElChanfle , Feb 27, 2015 :
    Add me to the random reboot club. So there won't be a patch update to address these issues? The last week of March is still way down the line.
    Chriss29 likes this.
  8. jobber72
    Jelly Bean Feb 27, 2015
    jobber72 , Feb 27, 2015 :
    Have you tried resetting your phone to factory settings? Solved all the shitty problems I had following the update. Phone is running smooth now again with super good battery life (way more than 2 days including couple hours screen time). Make sure to back up your data first!!
    ElChanfle likes this.
  9. akincansenol
    Froyo Feb 27, 2015
    akincansenol , Feb 27, 2015 :
    I can't switch to ART in developer menu. Argh! Because it's stuck in bootloop after that.
    I don't know why..
    Thank you for replied
  10. Faruha
    Ice Cream Sandwich Feb 27, 2015
    Faruha , Feb 27, 2015 :
    My GPS isn't working anymore. Anyone is else having issues with this after the update?
  11. Love2flash
    Gingerbread Feb 27, 2015
    Love2flash , Feb 27, 2015 :
    Anyone having issues where you
    use the speaker phone. callers saying you sound muffled. I had no issues prior to update? Also I noticed that I do not get lte signal once I'm in an late area. I have to reboot phone for lte signal to come on?
  12. Hardianto
    Hardianto , Feb 27, 2015 :
    How to back to 44s ?
    Any guidance ?
    Since I also want to downgrade ..
  13. Hardianto
    I'm on stock rom 11.0-XNPH05Q..
    When I charge the battery, even 100%, the indicator status still "charging" (there is a flash in the battery indicator & charging status when checked via software), can not be "charged".. Is it normal ?
    Is it hardware problem ato software bug ?
    Thanks.
  14. lokesh3440
    Honeycomb Feb 27, 2015
    lokesh3440 , Feb 27, 2015 :
    You must be having some app which is not ART compatible. That might cause boot-loop.
  15. Azi.bagh
    Eclair Feb 27, 2015
  16. ntinykumar
    Eclair Feb 27, 2015
    ntinykumar , Feb 27, 2015 :
    Same kind of issues I am facing. My touchscreen not at responsive. If I scroll menu and its pressed anyone menu and open the application. Battery is not per formative this time even. I am surprise its hardware issue or software
  17. Coke707
    Donut Feb 27, 2015
    yupasana55 and Chriss29 like this.
  18. ElChanfle
    Froyo Feb 27, 2015
    I was going to "bite the bullet" and just wait for CM12s, until I heard the release was scheduled 'til the end of March. F that, I need my Bluetooth. Will probably reset the phone.
  19. Kyle753
    Eclair Feb 27, 2015
    Kyle753 , Feb 27, 2015 :
    Bluetooth calling is broken with this update :S. I can pair with my car but no calls can be made.
  20. uagandhi
    Cupcake Feb 27, 2015
