35
CM11s 05Q issues thread
Are you experiencing issues with the latest update?
  1. Yes (OTA update)
    55.6%
  2. Yes (Manual flash .zip)
    13.5%
  3. No (OTA update)
    15.3%
  4. No (Manual flash .zip)
    5.5%
  5. Yes but not anymore
    1.3%
  6. Haven't updated yet.
    8.8%
  1. sebestjanowicz
    Cupcake Feb 12, 2015
  2. leifras
    leifras , Feb 12, 2015 :
    It's enough to change the style to the original theme or to change sms app to Google messenger.
  3. jeffmadrid
    jeffmadrid , Feb 12, 2015 :
    Hello... first time posting up. First issues I noticed was most apps animations were a little jerky and the battery life has dramatically been reduced. Found that it was Facebook Messenger responsible for the drain. Today the battery won't charge. Any fixes in the near future? Can't use the phone like this.
  4. newmad
    Honeycomb Feb 12, 2015
    cdrp83 likes this.
  5. mchon
    mchon , Feb 12, 2015 :
    This is due to incompatible theme, not necessarily 05Q. You'll have to reach out to whoever made the theme to fix this issue. Previous users had other themes where the background was white, so their white texts disappeared into the background. It seems like you have the opposite issue (black background). The fix is to change the background color of the messaging back to non-white/non-black, not necessarily for font styles. That said, I use default theme so I don't specifically know what changes the messaging app's background.
  6. BenWinchester
    Eclair Feb 12, 2015
    BenWinchester , Feb 12, 2015 :
    I've got my phone set so that when I plug in a charger: there should be a charging light, and when I adjust the volume there should be a sound: but there isn't! I'm running the 05Q build (which I updated to via twrp) :)
  7. jaco60
    Gingerbread Feb 12, 2015
    jaco60 , Feb 12, 2015 :
    I've updated since 2 days, with the zip file.
    All is fine : battery, camera, double tap, wifi, all...
    But i've still not found reliable informations about the "encryption device" bugs of previous releases (clear data, wifi issues...).
    Can someone confirms this encryption works as expected now (or not)?
    joejongue and unique.user like this.
  8. manuel19
    The Lab² - Oclean X Pro Elite Reviewer Feb 12, 2015
  9. Curt0176
    Ice Cream Sandwich Feb 12, 2015
    Curt0176 , Feb 12, 2015 :
    24 hours after the ota I had my first random reboot, I hope that was the first and only one
  10. wmm
    KitKat Feb 12, 2015
    wmm , Feb 12, 2015 :
    I'll be interested to know if you see an improvement in the speakerphone echo; it's still there in the 05Q update.
  11. joseportillor9
    joseportillor9 , Feb 12, 2015 :
    Double tap to wake is killing me. I have to tap so many time to wake it up, or tap it really hard. :( I feel disappointed and discouraged. Don't know what to do
  12. dysonno1
    dysonno1 , Feb 12, 2015 :
    How do you use audio fx? There are no options in the app for me, I don't get an option to select it when I play audio files and I can't open it from other sound playing apps.. Basically it might as well not be on the phone
  13. enzoferri3097
    enzoferri3097 , Feb 12, 2015 :
    Having problems with sending a video made with screen cast (latest software update )
    And maxxaudio dont work with play music
    And when using shuffle player maxxaudio wont open app crashes phone doesnt responde after that .. When pressing lock
    Screen goos black and wont responde until u reboot
  14. soryuuha
    soryuuha , Feb 12, 2015 :
    Since this is issue thread..
    1. Upon installation, fb messenger eat my battery until my One overheat. Uninstalled. Btw, Already noticed that fb messenger being top battery eater for past few days before update..
    2. Default font seems different and bigger, anyone have this issue?
  15. syedgj
    Froyo Feb 12, 2015
    syedgj , Feb 12, 2015 :
    Yea what the hell is with the profiles. A lot of the previous options are missing.
  16. webdevgirl
    Ice Cream Sandwich Feb 13, 2015
    webdevgirl , Feb 13, 2015 :
    Yeah, that's one of the things that prompted me to do the speakerphone fix even though it wiped my phone. I figured that, maybe, I could fix a few things at the same time. Unfortunately, it didn't fix the speakerphone issue. :(
  17. reyscott1968
    Jelly Bean Feb 13, 2015
    reyscott1968 , Feb 13, 2015 :
    prevent accidental wake up?? that could be the culprit.
  18. Curt0176
    Curt0176 , Feb 13, 2015 :
    Idk I will look into that and report back.
  19. subaryota
    Froyo Feb 13, 2015
    subaryota , Feb 13, 2015 :
    Minor issue:
    Owner info displayed on the lock screen is now not properly positioned and overlaps the date.
  20. joejongue
    Gingerbread Feb 13, 2015
    joejongue , Feb 13, 2015 :
    Can someone on the latest update check the alarm function specifically the ringtone for the alarm, some people I know are experiencing either no sound or just beeps regardless of the type of ringtone selected.
