CM11S features missing in CM12S
  1. jpatterson0138
    Cupcake Apr 17, 2015
    #81
  2. FayeMarkV
    Ice Cream Sandwich Apr 17, 2015
    FayeMarkV , Apr 17, 2015 :
    Miss the Astro Beam screen off from CM11S. Perhaps future OTA's will bring it back again?
    But it isn't reall such of a deal breaker to me. ;)
    #82
  3. zapp3d
    Cupcake Apr 18, 2015
    zapp3d , Apr 18, 2015 :
    yea man.. toggling has become a pain now!
    #83
  4. psamir_05
    Froyo Apr 18, 2015
    psamir_05 , Apr 18, 2015 :
    4K Video recording, double tap wake up and brightness control on status bar features are available on CM12S.
    #84
  5. the00guy7
    Donut Apr 18, 2015
    the00guy7 , Apr 18, 2015 :
    since this build was posted for manual flashing, this is the delta of the features that I've personally found missing aside CM11S
    *no audio controls on lock screen for most apps, therefore no volume hold to skip tracks
    *no safe audio volume feature to lower media volume when plugging in headphones(this was brilliant)
    *EVERY notification triggers a vibration whereas in cm11 there was an explicit option to either do that, or let apps handle the notifications.
    really freaking annoying stuff missing in this rom man. I'm highly considering reverting to my cm11 nandroid.
    #85
  6. qslig
    Froyo Apr 18, 2015
    qslig , Apr 18, 2015 :
    I have audio controls on the LS. I read that you might need to enable this under notif mng.
    I have no vibration on notifs either.
    #86
  7. parkalash
    parkalash , Apr 18, 2015 :
    Totally agree with you. Screen animations when you go into sleep are gone from display options, and quick toggle into silent or vibrate as well. And slider shortcuts is gone. thats the biggest blow i think... CM12S is both an upgarde as well as an downgrade with some functions missing imo.
    #87
  8. Manu Prakash Gupta
    Donut Apr 22, 2015
    Manu Prakash Gupta , Apr 22, 2015 :
    they are avalable for me too but i think custumizability has become a lot less and the ock screen was better before
    i liked it very much is there any way to revert back to original
    #88
  9. tttl
    Ice Cream Sandwich Apr 22, 2015
    tttl , Apr 22, 2015 :
    You may try to wipe the cache. This fixed my problem on alarm clock.
    #89
  10. Alexbobaz
    Eclair Apr 22, 2015
    Alexbobaz , Apr 22, 2015 :
    Didn't on mine....i think the problem is related to the plugghed/unplugged state of my phone during night. However I'm still far from solving it.
    #90
  11. mriganksinha
    Gingerbread Apr 22, 2015
    mriganksinha , Apr 22, 2015 :
    its called ambient lighting now - std lollipop feature.
    #91
  12. Busjen
    #92
  13. gsavstrom
    Cupcake Apr 22, 2015
    gsavstrom , Apr 22, 2015 :
    I seem to have found most of the things I was missing by reading this thread (thanks go out to everyone) but there is one thing that I can´t wrap my head around:
    How do I go about swtiching between performance modes?
    - When in 11S I could switch between battery saver, balanced and performance profile but now there's only the option to have "per-app profiles".
    Did I miss something?
    #93
  14. cjsavas
    Froyo Apr 22, 2015
    cjsavas , Apr 22, 2015 :
    It works if your phone is not plugged in. Not ideal but its a workaround. For the past 2 days my phone was off an unplugged and the phone turned on and the alarm went off.
    #94
  15. Alexbobaz
    Eclair Apr 22, 2015
    Quick boot?
    Thanks anyway, i will try tonight
    #95
  16. cjsavas
    Froyo Apr 22, 2015
    Tried QuickBoot and I had no luck. Make sure your alarm is set for at least a couple of hours ahead.
    #96
  17. sadhumaheswar
    Eclair Apr 22, 2015
    sadhumaheswar , Apr 22, 2015 :
    all the features are available
    #97
  18. Alexbobaz
    Eclair Apr 23, 2015
    Alexbobaz , Apr 23, 2015 :
    Tonight i tried: no quick boot , opo unplugged and the alarm set for 8 hours ahead and it worked
    #98
  19. daviell
    Cupcake Apr 23, 2015
    daviell , Apr 23, 2015 :
    I am also missing face unlock. A shame but not a deal breaker. Generally very happy. My only complaint is that the App themer works for a while, then seems to reset to default.
    #99
  20. tkimk
    Donut Apr 23, 2015
    tkimk , Apr 23, 2015 :
    I'm also missing face unlock. Not happy about it. I tried the advice earlier in this thread to set a pattern first, but still don't have the option.
