2
CM12 OTA Help?
  1. IwantAnOPO
    Eclair Apr 24, 2015
    IwantAnOPO , Apr 24, 2015 :
    So, i just got the OTA update for my OPO, and i would obviously like to update, but when i click "Install Update", it simply reboots me into the recovery, and when i press "Reboot now" it hasn't updated anything. This obviously is totally noobish of me, as i'm not familiar with the recovery, but i hope someone will still help me resolve my problem :D
    Thank's in advance!
    tjy724 and bitz like this.
  2. damo2010
    Honeycomb Apr 24, 2015
    damo2010 , Apr 24, 2015 :
    u may need to manually update so just go into cm recovery and find the file .zip and flash it
  3. SayMyName
    Jelly Bean Apr 24, 2015
    SayMyName , Apr 24, 2015 :
    You'll find the Zip file in sdcard/Android/data/com.cyngn.fota/cache
  4. IwantAnOPO
    Eclair Apr 24, 2015
    Um, i'm not sure where that would be located... Also, will this wipe my data?
  5. IwantAnOPO
    Eclair Apr 24, 2015
    OK, thank's!
  6. nash859
  7. damo2010
    It shouldnt do you want me to give you a video link of this? but just shut the phone off and hold volume down + power
    Mastaan likes this.
  8. hobgob
    Froyo Apr 24, 2015
    hobgob , Apr 24, 2015 :
    there was another thread with the same issue
    quote:
    "I went to android > data > cyngn.fota (something like this) > cache > select zip and flash it. This zip file is the file you downloaded. And I had the same problem and fixed it this way."
    worked for me
    tjy724, bklyn000 and TeamValor91 like this.
  9. TeamValor91
    Community Veteran Apr 24, 2015
  10. Larry
    Larry , Apr 24, 2015 :
    Follow the path that saymyname stated : sdcard/Android/data/com.cyngn.fota/cache
    No need to wipe.
    ElectricPickle likes this.
  11. IwantAnOPO
    Eclair Apr 24, 2015
    OK, thanks everyone! Just one more time to clarify: Will this wipe my phone's data?
  12. hobgob
    Froyo Apr 24, 2015
    no, it won´t
  13. IwantAnOPO
    Eclair Apr 24, 2015
  14. Deactivated User
    Apr 24, 2015
    bklyn000 and Naman Bhalla like this.
  15. IwantAnOPO
    Eclair Apr 24, 2015
  16. Nise
  17. weresloth
    weresloth , Apr 24, 2015 :
    For an 8MB patch I wouldn't worry about battery unless it's really half dead.
  18. Nise
    Nise , Apr 24, 2015 :
    50% or over is advised. Fuller charge better
  19. ManishGupta069
    Eclair Apr 24, 2015
    ManishGupta069 , Apr 24, 2015 :
    hey i installed the update using
    will my current be lost???? I mean what can i do coz i have the same problem????
  20. gjegadeesh
    Ice Cream Sandwich Apr 24, 2015
