58
CM12S Bugs Thread
  1. CasperTFG
    KitKat Apr 26, 2015
  2. grievor
    Honeycomb Apr 26, 2015
    grievor , Apr 26, 2015 :
    anyone having issues with cellular connection always diverting to 3G and not back to LTE?
  3. vijendrahs
    Ice Cream Sandwich Apr 26, 2015
    vijendrahs , Apr 26, 2015 :
    Theme problem, not ROM
  4. morecowbell
    Gingerbread Apr 26, 2015
    morecowbell , Apr 26, 2015 :
    Yes
  5. varun.poonia14
    Froyo Apr 26, 2015
    varun.poonia14 , Apr 26, 2015 :
    Battery backing up only for 5-6 hours. Irritating :mad:..... After so long Cyanogen releases update with lots of bug.. Cyanogen CEO can abuse people but can't take stand what his team done. Better buy some renounced brand then we will get sooner updates and good quality product. Useless company that is cyanogen. Soon will die ..:mad:
  6. Glocninez
    Cupcake Apr 26, 2015
  7. vrsreekanth
    Froyo Apr 26, 2015
    vrsreekanth , Apr 26, 2015 :
    Ad of now this cannot be considered as an upgradation. Only problems..no benefits. The major issue is battery drain.its worst than a Samsung grand..!!!
    Also didn't understand why they removed 'sync' option from notification panel. Also removed auto contrast option. But this options are available in power managemnet widget.
    The dialar app keep crashing.
    The streaming is not so smooth. Especially YouTube.(don't sure whether its a YouTube issue)
    Lookwise.. Dont use app drawer in night. It can blind you.dirty white background.
    Overall the cm12 is 100% shit. Those who are still running on cm11 is very lucky.
  8. Mandraker
    Froyo Apr 26, 2015
    Mandraker , Apr 26, 2015 :
    I'll give you 125 dollars for that Oneplus you got right there, your absolutely right! Oneplus means nothing! So sell that phone to me :D American dollars or euro's?
  9. peteski79
    peteski79 , Apr 26, 2015 :
    Another vote for terrible battery. Barely get through a day now, instead of almost 2 days. Seems android system is possibly to drain. Weatherzone became a problem for the battery but I've changed the privacy for wake up now and it's good again.... Just re damn "android system" app.... Also wifi seems to be on /active all the time? Any suggestions? Screenshot_2015-04-26-17-54-28.png Screenshot_2015-04-26-17-53-05.png
  10. hemanttap
    hemanttap , Apr 26, 2015 :
    Wifi/Mobile Network seem unstable- For me this is only cause during when you connected to WIFI and your Mobile network will lost connection.
    I'm facing the same problem. This -> ! <- icon annoying me. Help.
  11. valpet
    valpet , Apr 26, 2015 :
    Have you red all the bug report? I don't think so..
  12. PassiTheApe
    Eclair Apr 26, 2015
    PassiTheApe , Apr 26, 2015 :
    I have a big issue with video playback....YouTube works fine but for example on IMDB the video s lag or stop at some time, in every video. So annoying -.- what an update
  13. aleeone
    aleeone , Apr 26, 2015 :
    Me too, both my wife and I have a One Plus One, I manually update my wife's One to cm12, speaker sound becomes 50% and headphone sound becomes 60% of my set running on 11s. Google Play Music in the new version is not able to read wma as well as some lossless format. Hope Cyanogen will resolve this soon. I am waiting for that before upgrade to CM12.
  14. chema43
    chema43 , Apr 26, 2015 :
    Esta mañana al actualizar un tema que compre se colgó la aplicación, y luego siguió como si nada.
  15. tempe
    Eclair Apr 26, 2015
    tempe , Apr 26, 2015 :
    Bugs so far: Custom ringtone stopped working. Opening flipcover doesnt wake the phone everytime, seems less sensitive. Setting phone to silent profile twice in a row will even disable alarms.
  16. PbjDude
    Froyo Apr 26, 2015
    PbjDude , Apr 26, 2015 :
    Battery drain issues
    https://forums.oneplus.net/threads/combined-battery-drain-issues-thread.286369/
    This worked for me:
    FIX #1 (no root needed)
    Settings Privacy Guard:
    Go to Privacy Guard, and Disable "Wake" and "Keep Awake"
    (Settings > Privacy > Privacy Guard > (press the top right corner to the right of reset) > (Check) Show built-in apps
    Then scroll down until you find "Google Play Services", Disable "Wake" and "Keep Awake", and turn on Privacy Guard for "Google Play Services"
  17. semper80
    semper80 , Apr 26, 2015 :
    This is CM11S, no?
  18. semper80
    PFFFF.... The OS is optimized for battery. Clear Data in TWRP. Brothers! When you learn?! If you notice some bugs in an OS, do not report it as a BUG until that you Clear Cache and Data. Only after these steps you can say an OS / ROM has bugs.
    dtheem likes this.
  19. semper80
    I have used this OS for a few days and I can say that it has quite a few bugs. Battery lasts two days without emotion: active wifi, 4G enabled, calls 1h40min. Phone was use between balanced and aggressive.
    Many of BUGs reported by you, aren't the operating system bugs. They are conflicts with data stored in other ROMs that you've used them before.
  20. kanden95
    Eclair Apr 26, 2015
    kanden95 , Apr 26, 2015 :
    Does this newest update for the opo drain the battery for you guys as fast as it does for me? Without doing anything the battery depletes really fast. I'm talking about YNG1TAS17L
