58
CM12S Bugs Thread
  1. Erebus94
    Honeycomb Apr 14, 2015
    Erebus94 , Apr 14, 2015 :
    The old one does not work anymore. You have to create a new one
    York_21 likes this.
  2. Deactivated User
    Apr 14, 2015
  3. giacomogio
    Cupcake Apr 14, 2015
    giacomogio , Apr 14, 2015 :
    The Contacts order preference "First name first" is not being saved. Everytime I reboot the phone it displays the contacts last name first even if "First name first" is selected.
    A temporary solution is selecting "Last name first", view the contacts and then change it to "First name first". I need to do it every time I reboot.
  4. Erebus94
    You can change it in the theme chooser. Click on the theme you are using and there is an option to customize lock screen wallpaper.
  5. Erebus94
    Does anyone have a problem of keyboard not displaying properly (not expanding) in landscape mode?
  6. jhb019
    Froyo Apr 14, 2015
    jhb019 , Apr 14, 2015 :
    Don't know if anyone has already said this, but the OS shouldn't come rooted. If oneplus and cyanogen want the os to come bundled with gapps, google will not allow them to have root inside the os. To get root you just have to flash supersu through recovery.
    York_21 likes this.
  7. York_21
    Gingerbread Apr 14, 2015
    York_21 , Apr 14, 2015 :
    No issues here.
    All the people that are complaining need to do a clean install...
  8. ajem
    ajem , Apr 14, 2015 :
    As you guys can see, when I enter notification drawer, there are artifacts on the screen. Anyone has any idea what causes this and how can I get rid of it?
  9. Hans P.
    Ice Cream Sandwich Apr 14, 2015
    Hans P. , Apr 14, 2015 :
    Can I ask you why? :confused:
  10. SomeSayImHandSome
    Apr 14, 2015
    SomeSayImHandSome , Apr 14, 2015 :
    not true. I don't know what other brands your talking about. but that's not on this planet that's for sure. as long as I remember OTA's were always like this no matter if it was apple android. or windows phone
    there's just something about OTA's that introduce bugs when going from one major update to another. same thing with windows on a PC. people who "upgrade" instead of clean install always have some sort of wacky issue. its just the nature of software
    maxvorstadt23 and rubenalamina like this.
  11. giacomogio
    Can you check if the contacts order preference "First name first" is being saved in your phone after a reboot? I did a (ultra) clean install. I did have the same problem with CM12 nightlies.
  12. Umiamz
    Umiamz , Apr 14, 2015 :
    The old account was a Cyanogenmod account - you need a new Cyanogen account for this update.
    neyzen69 likes this.
  13. rrainwater
    rrainwater , Apr 14, 2015 :
    Yeah. It is crazy. BTW, I think before someone posts one more time about a setting not saving maybe they should seriously consider installing the ROM correctly. At this point I am not going to bother even replying to those posts.
  14. knollorulez
    Donut Apr 14, 2015
    dougclaudia likes this.
  15. sergioreja
  16. Tyronekramsey
    Jelly Bean Apr 14, 2015
    Tyronekramsey , Apr 14, 2015 :
    I said some people may not. I just put these in because multiple users are reporting these
  17. arunragavan
    arunragavan , Apr 14, 2015 :
    After upgrade, I had used PIN lock on the phone. After the initial setup of the pin,i tried to unlock it doesnt work. What do I do now? I am unable to use the set pin for unlocking the phone.
  18. Umiamz
    Yes, the Messaging app crashes if you have ANY other SMS app set as the default, I've found. If you set Messaging as the default SMS app then no more FCs.
    This is a known bug that also affects the CM12 nightlies, too, and it doesn't matter whether it's a fresh or a dirty install.
  19. AntMunny
    KitKat Apr 14, 2015
    AntMunny , Apr 14, 2015 :
    Same issue an on every other cm12 based rom...audio via bluetooth to my car is sped up...music as well as gps voice nav
  20. wardell
    Eclair Apr 14, 2015
    wardell , Apr 14, 2015 :
    I was getting this issue a lot with CM11S and the MultiROM Kernel, but it was fixed by flashing the franco.Kernel, so I imagine it might fix it here, too.
