58
CM12S Bugs Thread
  1. sbenson
    Ice Cream Sandwich Apr 14, 2015
    sbenson , Apr 14, 2015 :
    This is complete bullshit. Oxygen OS fixed the flash issue, yet Cyanogen hasn't been able to fix this issue in 8 months.
  2. patstar5
    Jelly Bean Apr 15, 2015
    patstar5 , Apr 15, 2015 :
    Well I wiped calendar, calendar storage, contacts, and contacts storage data and I still get it. Dialer app doesn't work either.
  3. sonygoup
    Honeycomb Apr 15, 2015
  4. nicerous
    Gingerbread Apr 15, 2015
    nicerous , Apr 15, 2015 :
    I did the same! still having the problem :/ thinking about a clean install of cm12s...
  5. JuanpaG94
    Eclair Apr 15, 2015
    JuanpaG94 , Apr 15, 2015 :
    I know. Yesterday I was on CM12 nightlies, but i'm going to return back.
    CM12s have more bugs than CM12 nightlies... And when there is any bug, it's solved quickly in the nightlies.
  6. patstar5
    Well I'm wiping cache (again), been googling and one person uninstalled facebook and it worked. So I guess I will try that and try gmail.
  7. Gaspertrix
    Cupcake Apr 15, 2015
    matanras likes this.
  8. rcarbajal
    rcarbajal , Apr 15, 2015 :
    I enabled the open music player when headphones are plugged in option under sound which resulted in my phone rebooting every time I plug in headphones/audio cable.
  9. DigitalAnarchy
    DigitalAnarchy , Apr 15, 2015 :
    Just tried it now......
    went from 05Q, used fastboot to flash to cm12s, it took out twrp recovery, i'm guessing as i did it the fastboot way that's to be expected, so probably a non issue just wanted a complete clean flash to minimize any bugs due to old o.s.
    wi-fi 5GHz networks aren't being detected, apart from that it seemed pretty nice
    also trying to re-flash twrp 2.8.6.0 once your on cm12 recovery wouldn't work even on using erase and flash commands
    anyway, went back to 05Q, re-flashed twrp then restored my backup, this worked
  10. CZeph
    CZeph , Apr 15, 2015 :
    I used to be able to go under Developer Settings to install unknown sources but I don't see that option. I suppose I can do it with root explorer. Also, changing the icons from large to small on the home screen doesn't seem to work for me - still huge.
  11. sonygoup
    sonygoup , Apr 15, 2015 :
  12. emirfaez
    Donut Apr 15, 2015
    emirfaez , Apr 15, 2015 :
    My wifi is ok but the problem is the mobile data..i dont know why after i use cm12s, the internet is too damn slow .. It is happen when i flash oxygen too.
  13. Ronpopeil7
    Froyo Apr 15, 2015
    Ronpopeil7 , Apr 15, 2015 :
    I am having the same issue. Only happens in my car. I have a Bluetooth speaker, and headphones that play just fine. I drive a 2012 Mazdaspeed 3.
  14. AntMunny
    KitKat Apr 15, 2015
  15. patstar5
    Must be something 3rd party, everything works in safe mode
  16. michaelj
    michaelj , Apr 15, 2015 :
    Flashed from stock 05Q using CM recovery. Didn't wipe data or anything, simply upgrade zip file and reboot.
    Rebooted and baseband was unknown. Had a whole lot of complaints about google play services etc. (which is understandable when moving to lollipop)
    Had a notification pop up to upgrade CM recovery, popped into developer options and ticked the box to use CM recovery.
    Rebooted into recovery (now it was updated) and went through the flash process again.
    Reboot and it didn't pick up reception straight away, took about 30 seconds, phone was left alone and it automagically connected to google and updated all the apps etc. around 2mins later the phone was back to normal.
    I've rebooted the phone several times now to try to recreate the issue, it's definitely gone away.
  17. matanras
    Donut Apr 15, 2015
    matanras , Apr 15, 2015 :
    Here are two I found: status bar Auto Rotate has the portrait icon on startup(with a lock), changing users crashes CM Logger, you have to reboot.
  18. jeffery
    jeffery , Apr 15, 2015 :
    It is cyanogen trade mark saying nothing in this world is perfect, accept it or gtfo. :D
  19. domoham
    Froyo Apr 15, 2015
  20. JopeTski
    Donut Apr 15, 2015
    JopeTski , Apr 15, 2015 :
    I have the same issue @slash28cu . i installed the new messenger app and there's no more "Messaging has stopped working" but everytime i restart the phone, the "Android is upgrading" message still persists.
