CM12S Music Player issue
  1. adriandistel
    Eclair Apr 14, 2015
  2. FoleyRose
    Ice Cream Sandwich Apr 14, 2015
  3. adriandistel
    Eclair Apr 14, 2015
  4. FoleyRose
    FoleyRose , Apr 14, 2015 :
    It's working fine for me, I just took a walk while listening to music. Maybe a reboot?
  5. adriandistel
    Eclair Apr 14, 2015
  6. nathaneous
    Gingerbread Apr 17, 2015
    nathaneous , Apr 17, 2015 :
    Anyone lost their album art on Google Music Player since upgrading to CM12?
    For some reason all my album art has disappeared? I save music locally on my device and the album art still shows up in other music players but I'm not sure what has happened with Google Music Player?
  7. iDelirious
    Gingerbread Apr 19, 2015
    iDelirious , Apr 19, 2015 :
    Yup, I'm facing the same issue, I normally use Shuttle+ but tried Google Music player as well. A few albums were missing, some album art not there etc. I deleted all my music and downloaded them once again, same problem, some albums there and some missing.
  8. nathaneous
    nathaneous , Apr 19, 2015 :
    I resolved this by doing the following...
    Go to the Google play music app in application manager and clear all data and clear cache. Restart Google Play and everything should be there again...
  9. amarkenzon
    Froyo Apr 19, 2015
    amarkenzon , Apr 19, 2015 :
    Update the google play services thing with the update found on the forums.
  10. iDelirious
    Tried that didn't work unfortunately. I downloaded Poweramp, sort of works, because it shows you all the files with audio that it can play, so I've got all my albums but it also shows other audio which is a bit annoying.
  11. Thidasa
    Gingerbread Apr 20, 2015
    Thidasa , Apr 20, 2015 :
    Can u kill the app from Notification drawer while music is playing ?
  12. FoleyRose
    Ice Cream Sandwich Apr 20, 2015
    FoleyRose , Apr 20, 2015 :
    No, can't swipe it out while music is playing, but that's normal. Why?
  13. ShashwatA
    Cupcake Apr 20, 2015
    ShashwatA , Apr 20, 2015 :
    I swear... You can't kill the app from the drop down drawer and you can't exit it manually.
    Also, if you kill the app.... It doesn't freaking load... You have to clear the cache...
  14. adriandistel
    Eclair Apr 20, 2015
    adriandistel , Apr 20, 2015 :
    It was after the CM12s update, so a reboot solved the problem.
  15. isamardziev
    Cupcake May 10, 2015
    isamardziev , May 10, 2015 :
    I'm having the same problem pretty much all of yge albums I had before the update are albumart-less. Only a handful still have it one of them I just downloaded. Reboot didn't help nor did the app cache.
  16. G_Rajeshkumar_Rajendran_
    Cupcake Jul 11, 2017
