46
CM12S now available!
DO YOU LIKE CM12?
  1. You Like it
    58.4%
  2. Will wait for BUG fixes
    34.2%
  3. Dont like.
    12.5%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. mckenn
    Froyo Apr 24, 2015
    mckenn , Apr 24, 2015 :
    Install
  2. chetanburande
    Froyo Apr 24, 2015
    Settled likes this.
  3. munezbn
    Donut Apr 24, 2015
    munezbn , Apr 24, 2015 :
    These settings are only applicable "when device is locked" ..
    OK forget about all.. Add two messengers(whatsapp, hike) in a folder and lock the folder (not phone) by clicking on small lock button and set a password.
    Now you can open whatsapp and hike only with password. You cannot open them without password.
    But if you receive a message and click on that noification it will open the Whatsapp without asking for password....
  4. BLZB0B
    Cupcake Apr 24, 2015
    BLZB0B , Apr 24, 2015 :
    Somebody at cyanogen is extracting the urine with this non release me thinks
  5. Mehbz
    Honeycomb Apr 24, 2015
  6. mckenn
    Froyo Apr 24, 2015
    It looks exactly the same
  7. peteski79
    Gingerbread Apr 24, 2015
  8. peteski79
    peteski79 , Apr 24, 2015 :
    And once installed, next update came through straight away. Not rooted device.
  9. junedawn
    Froyo Apr 24, 2015
    junedawn , Apr 24, 2015 :
    Queens New York. Just got the update. Will install when I get home. Looking forward to having a little Lollipop sweet treat. Will report.
  10. DeFQoN_1_469
    DeFQoN_1_469 , Apr 24, 2015 :
    I have downloaded cm12s over the air, but how do install it because when i'm pressing on install, i'm coming in cyogen recovery mode. Then i'm stuck at it. Could somebody tell me what to do next.
  11. Perfection7
    Eclair Apr 24, 2015
    Perfection7 , Apr 24, 2015 :
    I did the instal where u don't have to root and stuff. But i missed the wipe partition cache bit. Is that gonna be a big deal?
  12. sabbeman
    Eclair Apr 24, 2015
    sabbeman , Apr 24, 2015 :
    I've been on nightlys for a while then Oxygen then YNG1TAS17L...and the 5GHz never worked on CM12 but some how it works on Oxygen!
    Wonder how they did it?! Also hope CM will fix it soon! Because that's one thing I was expecting to be fixed in CM12s!
  13. onema647
    Ice Cream Sandwich Apr 24, 2015
    onema647 , Apr 24, 2015 :
    I'm having the same problem I don't know what to do when I get to recovery mode
  14. sudhakarjha
    sudhakarjha , Apr 24, 2015 :
    No OTA yet for me.. Still waiting the the official rollout percentage is still 5 only.. Seems like paused again
  15. peteski79
    Same problem here. Where is the updated file saved?
  16. bkbkjbb
    bkbkjbb , Apr 24, 2015 :
    When will people ever realize there is NO! CM12s!!!!!!
    They called it CM OS12 so say that.
  17. peteski79
    OK, figured it out guys. Just need to find the where the update file was stored on the phone then install it in recovery . To find the update file, I used astro file manager to search and find the YNG.... file. Anyway this should work. follow steps below...
    tap the 'apply update' notification and wait till phone reboots into recovery.
    tap 'internal storage'
    tap O/
    tap android
    tap data
    scroll down and find 'com.cyngn.fota/' and tap it.
    tap cache
    update file should be in this folder - cm-12.o-YNGITAS (or whatever it's called)
    tap on file and it starts update.
    Phone will finish and go back to recovery.
    tap reboot system
    phone reboots (took quite a while compared to normal reboot)
    get message of android upgrading
    optimizing X of Y apps..... (X and Y = whatever number of apps you have....
    Worked perfectly. just need to work out how to use 5.0 now! hope this helps guys.
    williamhaven likes this.
  18. Mat972
  19. ashley27
    Froyo Apr 25, 2015
    ashley27 , Apr 25, 2015 :
    Flash it without any hesitation. I lost patience too and everything works perfectly with the new UI etc.
    Mat972 and Deactivated User like this.
  20. Mat972
    Honeycomb Apr 25, 2015
    Mat972 , Apr 25, 2015 :
    Thanks, I'll do it right now
