46
CM12S now available!
DO YOU LIKE CM12?
  1. You Like it
    58.4%
  2. Will wait for BUG fixes
    34.2%
  3. Dont like.
    12.5%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. matias.cova
    Cupcake Apr 30, 2015
  2. Deactivated User
    Apr 30, 2015
  3. Sourav1982
  4. ipilcher
    ipilcher , Apr 30, 2015 :
    I'll avoid it like the plague unless Google fixes the trainwreck that is Google Voice integration in Lollipop (or CyanogenMod brings back Voice+).
  5. Sourav1982
  6. gcavelie
    Eclair Apr 30, 2015
    gcavelie , Apr 30, 2015 :
    The OTA are not geographically delivered, therefore nobody can answer you... but they said that the rollout should be completed by end of the week... Just wait a little bit more or flash it ;)
  7. praveen kumar dharla
    praveen kumar dharla , Apr 30, 2015 :
    Hi,
    Today morning i got a message that CM 12 is available for updqate for me, after download when i clicked on intall, it propted for reboot, after reboot nothing is happening
    i check the "about phone" ther it shown only CM11 and nothing is present in download
    can someone help me
  8. Rogernils1
    Donut Apr 30, 2015
  9. jeanguy2
    Froyo Apr 30, 2015
    jeanguy2 , Apr 30, 2015 :
    From what you say above it looks like you have only applied the small ~ 7.8 MB preparatory OTA to CM11 to get it ready for the second major OTA to CM12. Just wait a little longer and a second ~ 598 MB OTA will come to you to update to Cyanogen 12.0 - YNG1TAS17L. This new OTA is now being rolled out in two phases. Phase 1 is the minor update to 11s and phase two is the actual major OTA to CM 12. Keep checking the update option in your setting under "About"
    Good luck...
  10. jeanguy2
    Froyo Apr 30, 2015
    Update my rooted OPO from CM 11 to CM 12 today using the new two phases OTA update/upgrade. Update/upgrade went quite smoothly but, as expected, the upgrade to CM12 did unroot my phone.
    Re-unlocking the bootloader, re-installing TWRP to replace Cyanogen Recovery APK and installing Super SU 2.46 did the trick. Phone is now rooted again & working without any major discrepancies.
    So far, I very much like the new look and feel of Android 5.0.2.
  11. SrPhaeton
    Donut Apr 30, 2015
  12. joseluiscence
    Froyo Apr 30, 2015
  13. jasvinder singh
    Donut Apr 30, 2015
    jasvinder singh , Apr 30, 2015 :
    http://builds.cyngn.com/cyanogen-os...816218e8a/cm-12.0-YNG1TAS17L-bacon-signed.zip
    not working
    please fix it
  14. chetasmapara
  15. ScorpioPirate
    Ice Cream Sandwich Apr 30, 2015
  16. ScorpioPirate
  17. Spyrious
    Gingerbread Apr 30, 2015
    Spyrious , Apr 30, 2015 :
    Sorry i know it may have been aswered before,but i'm on cm11s stock and francos kernel.I received the update.Can i install it or will i have any problems?Thanks
  18. vot4pedro
    Froyo Apr 30, 2015
    vot4pedro , Apr 30, 2015 :
    I cant believe my eyes! I have the update sitting in queue.
    Location- Southern California USA
    OPO purchased November, 2014
  19. ScorpioPirate
  20. Ritzzz
    Froyo Apr 30, 2015
    Ritzzz , Apr 30, 2015 :
    I got a message in my notification for it. But when i tried to update it was not reflecting
