46
CM12S now available!
DO YOU LIKE CM12?
  1. You Like it
    58.4%
  2. Will wait for BUG fixes
    34.2%
  3. Dont like.
    12.5%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Peppie
    Gingerbread May 13, 2015
    Peppie , May 13, 2015 :
    I found the bin in the cm12s ZIP, but should I get it out of the zip? what do I have to do?
    And if I would like to run Blisspop again, should I flash another modem?
  2. gumfi
    gumfi , May 13, 2015 :
    Yes out of ZIP and use fastboot, When you flash, not using fastboot, modem is not flashed
  3. haro94
    haro94 , May 13, 2015 :
    @Peppie Please. Just use your phone as it is and stop re-flashing/dirty re-flashing when you have no app errors etc. it takes time for the battery and phone to recal to the new ROM. and it's not about the modem.. @gumfi giving wrong directions..
    benchmark apps are not totally accurate and they are used to do little comparisons between market flagships, as opposed to judging by your personal standards of how the phone matches up to you. so why be so bothered to compare your benchmark scores with your friends?
  4. gumfi
    Ok i'm on cm12s flash cm11s When screen is off i cant turn on screen, then i flash modem from cm11s and all work again
  5. haro94
    i dont even. understand how that relates to his(Peppie's) issue..
  6. Peppie
    I Like to check out new roms, but I didn't dirty flash one of them. So, to fix the issue i just have to push the modem file to my opo with fastboot?
  7. gumfi
    yes you can always flash new rom if flashing modem not did if for you, let me no:)
  8. gumfi
  9. Peppie
  10. gumfi
    phonegeek101 likes this.
  11. Peppie
    it worked, The touches respond much better, so thank you!!!
    If I do a total wipe, and then flash a new ROM (Blisspop), should I manually flash their modem if that one is slow?
  12. gumfi
    Good, i dont no blisspop, but if there is a modem bin file then i will say yes
    CaKiTarZ likes this.
  13. sattaru
    Cupcake May 14, 2015
  14. mghema
  15. davidac
    davidac , May 14, 2015 :
    I still have not got the updates. It just says and update is available and all I can do is cancel it. It says I will be notified when the update is ready for me
  16. PidoRas
    Eclair May 14, 2015
  17. french1423
    Cupcake May 15, 2015
    french1423 , May 15, 2015 :
    Can't decide whether to wait patiently for an OTA update to fix the ton of bugs it's riddled with or flash and 'settle' with CM11s... Better to settle with something good than keep changing all the time and not having a phone that does what you need.
  18. lynchknot
    Donut May 16, 2015
  19. x1123
    Cupcake May 17, 2015
    x1123 , May 17, 2015 :
    AFAIK Cyanogen OS released by OnePlus, CyanogenMod released by Cyanogen Community. So OnePlus (one) has 2 options of "Stock" OS CyanOS and OxygenOS.
  20. ITSMElaksh
