46
CM12S now available!
DO YOU LIKE CM12?
  1. You Like it
    58.4%
  2. Will wait for BUG fixes
    34.2%
  3. Dont like.
    12.5%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Huguleyite
    Donut Apr 14, 2015
  2. ScorpioST
    Eclair Apr 14, 2015
  3. 15kjpatel
    Honeycomb Apr 14, 2015
    15kjpatel , Apr 14, 2015 :
    I'm on night lies rn.. Should I go back to KitKat then do it.. And also what do I wipe
  4. aumpandya07
    Eclair Apr 14, 2015
    aumpandya07 , Apr 14, 2015 :
    How ? Im also from India :(
  5. Louluvre
    Jelly Bean Apr 14, 2015
  6. fazlee712
    Eclair Apr 14, 2015
  7. azndoodle
    Froyo Apr 14, 2015
    sirlimewire, guptap11 and Dmaxless like this.
  8. BamBaz0r
    Eclair Apr 14, 2015
    BamBaz0r , Apr 14, 2015 :
  9. 15kjpatel
    Let me know what happens
  10. Dmaxless
    Froyo Apr 14, 2015
    Dmaxless , Apr 14, 2015 :
    Damn seems like i will have to take my charger to school tomorrow morning....
  11. Kapitan Nemo
    Lollipop Apr 14, 2015
    Kapitan Nemo , Apr 14, 2015 :
    Dá para instalar pelo TWRP sem problemas. Acabei de instalar, pelos vistos não se trata de um fastboot signed como aqueles que eles colocam no site deles.
    Instrucoes em ingles para instalares se tiveres duvidas dispoe.
    First you need to download this ROM image and have it on your phone.
    After, you need to go to TWRP -> Wipe -> Advanced Wipe and then check Dalvik Cache. Then Swipe to wipe.
    Always inside TWRP you should go to TWRP -> Install -> Then browse your phone files on the sd card until you find the ROM image.
    After installing wipe the Dalvik Cache.
    Gallark and Miguel Quezada like this.
  12. doddysal
    Ice Cream Sandwich Apr 14, 2015
    orestis and twacrs like this.
  13. drramith
    Gingerbread Apr 14, 2015
    drramith , Apr 14, 2015 :
    Those who are getting ota updates please inform their purchase date also.....
  14. Deactivated User
    Apr 14, 2015
  15. eeswaratluri
    Cupcake Apr 14, 2015
  16. Chris Haidze
    Chris Haidze , Apr 14, 2015 :
    Copied from another thread:
    Here's the steps:
    1. Download the OTA
    2. Turn off device.
    3. Turn on device while holding volume down (select recovery) and press power.
    4. Apply update (from device) navigate your way to your download folder and select the zip file and apply. To navigate use volume up and down and select with power.
    5. When the updates done go back and wipe cache.
    6. Reboot and enjoy.
    https://forums.oneplus.net/threads/...simple-no-computer-needed.84161/#post-4074500
  17. Heartthrob
    Froyo Apr 14, 2015
  18. Donoban
  19. clubdude
  20. Varun Mokashi
    Donut Apr 14, 2015
    Varun Mokashi , Apr 14, 2015 :
    some files might be for the OTA update since we are downloading the zip it might hav been removed
