46
CM12S now available!
DO YOU LIKE CM12?
  1. You Like it
    58.4%
  2. Will wait for BUG fixes
    34.2%
  3. Dont like.
    12.5%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. ThulsZ
    Froyo Apr 14, 2015
  2. raullow
    Donut Apr 14, 2015
    raullow , Apr 14, 2015 :
    OK the step is:
    1) off your phone
    2) hold volume down and power button
    3) Apply update and find the file you downloaded on the mega folder or the place that you paste the zip file
    4) tap and wait
    Hope it helps
    Thidasa and webdevgirl like this.
  3. jmkd
    Honeycomb Apr 14, 2015
    jmkd , Apr 14, 2015 :
    I did flash my phone for Oxygen OS...does it mean I wont get CM12 update?
  4. BTORRES2012
    BTORRES2012 , Apr 14, 2015 :
    yep and it worked for me trough stock recovery :)
    swamych likes this.
  5. vag2008
    Gingerbread Apr 14, 2015
  6. shivamshah1733
    shivamshah1733 , Apr 14, 2015 :
    D-load the ota file
    power down phone, volume key down+power key
    clear partition cache, thing.
    apply update, scroll down to where you placed the zip folder.
    Android is upgrading.
    Reus and Qamermax like this.
  7. ThomasP_HK
    ThomasP_HK , Apr 14, 2015 :
    I tried this, but I get an error message when I select "from internal storage". My thinking is that this is because my data is encrypted?
  8. 1ikhan
    Ice Cream Sandwich Apr 14, 2015
    1ikhan , Apr 14, 2015 :
    your best bet is to wait for the ota.
  9. domecamm
    domecamm , Apr 14, 2015 :
    Works whit TWRP? I try, but it doesn't find it...and which fast boot say
    "archive does not contain 'android-info.txt'
    archive does not contain 'android-product.txt'
    error: update package has no android-info.txt or android-product.txt"
    :confused:
  10. hastaguy
    hastaguy , Apr 14, 2015 :
    Not yet. Waiting for it.
  11. Qamermax
  12. sudhakarjha
    sudhakarjha , Apr 14, 2015 :
    Go and feed some parrots, you will surely get it.
    Deactivated User likes this.
  13. smevolution
    Deactivated User and CaneDrew like this.
  14. Jamesst20
    Jelly Bean Apr 14, 2015
  15. mgb2012
    Eclair Apr 14, 2015
    mgb2012 , Apr 14, 2015 :
    Just installed the zip from megaupload using these instruction.
    Workiong like a charm!
    aman360elite and mrsurehsisha like this.
  16. rkiwtir
  17. jbollaert
    KNO56 likes this.
  18. Louluvre
    Louluvre , Apr 14, 2015 :
    Can't arge to that.
    To flash a new rom, you have to enter bootloader and then root, yes, it will wipe all your data (always make a backup). You can find lots of info on how to do all this if you look around the "Development section". If you run into trouble then you can ask here.
  19. vy7478
    Eclair Apr 14, 2015
    vy7478 , Apr 14, 2015 :
    Haha I sure that will work! :)
  20. sajeed
    aumpandya07 likes this.
