shrey7
Jelly Bean
Apr 23, 2015
Hi Guys,
CM12S YNG1TAS17L official build is now rolling out.. Yes OK Oneplus is included in this build.. If you already got an OTA update then you are lucky. If not just follow the instructions below and flash the zip. All the best
FIRST OF ALL YOU NEED TO DOWNLOAD LATEST BUILD..
CLICK ON THE FOLLOWING LINK TO DOWNLOAD CM12S YNG1TAS17L LATEST BUILD:
http://builds.cyngn.com/cyanogen-os...816218e8a/cm-12.0-YNG1TAS17L-bacon-signed.zip
INSTRUCTIONS FOR NON-ROOT USERS:
(STOCK RECOVERY)
First you need to download zip and put it on internal storage of your phone.
REBOOT INTO RECOVERY
SELECT >> APPLY UPDATE
SELECT >> INTERNAL STORAGE
SELECT >> 0
SELECT >> cm-12.0-YNG1TAS17L-bacon-signed
SELECT >> YES
NOW RESTART AND ENJOY FEATURES LIKE OK ONEPLUS
SCREENSHOTS COMING SOON..
INSTRUCTIONS FOR ROOTED USERS:
(TWRP RECOVERY)
IMPORTANT NOTE: INSTALLTION WILL WORK ONLY WITH LATEST TWRP VERSION: 2.8.6.0
SELECT >> INSTALL
SELECT>> (YOUR DOWNLOADED FILE: cm-12.0-YNG1TAS17L-bacon-signed)
SWIPE TO FLASH
SELECT WIPE CACHE/DALVIK
SELECT REBOOT SYSTEM
NOTE: AFTER SELECTING REBOOT SYSTEM.. IT MAY PROMPT YOU TO INSTALL SUPER SU (ROOT APP) GO AHEAD AND INSTALL IT.
Now you are all set
CHANGE LOG:
1) "OK ONEPLUS" Voice command is included..
2) Google Services upgraded to 7.3.29 (Thanks @VinceCgto)
3) [FIXED] Messaging app crashing on boot (Thanks @VinceCgto)
4) [FIXED] OTA fails due to encryption (Thanks @VinceCgto)
5) [FIXED] Improve Theme engine (Thanks @Mike9966)
FAQ'S
Q) Is this a stable ROM?
a) Yes its a stable ROM.. so far i didn't face any issue.
Q) I am on CM 11S can i directly apply this update?
a) Absolutely..
Q) I am on Oxygen OS can i flash this zip?
a) Yes.. try this method
https://forums.oneplus.net/threads/guide-ota-manual-install-easy.297425
Q) I already flashed the previous version of cm12s (yng1tasoyl). Is there any incremental update for this version available or I need to download and flash full rom?
a) Yes, you must flash full zip.. no other option.
Q) Will this wipe my data if flashed with TWRP?
a) Not unless you do advance wipe.. so just stick to the instructions then your data will be safe. (Questioned by: @sa00044)
Q) I am on STOCK ROM 12S with rooted and TWRP installed.. can i directly apply this update? (Questioned by: @chebyr)
a) Yes, make sure you flash file from TWRP.
Q) Will i get OTA updates in future?
a) If you are on STOCK ROM with STOCK RECOVERY.. then YES.
Q) I'm having the same issue as a few others where I had my system download the OTA and then when I try to apply it, the system restarts in recovery and asks me to find the file. Where should I go to find the file? (Questioned by: @jabbajac )
a) sdcard/Android/com.cyngn.fota/cache - (Answered by: @deetee )
More coming soon..
INSTRUCTIONS TO ACTIVATE "OK ONEPLUS" VOICE COMMAND ON YOUR PHONE:
https://forums.oneplus.net/threads/...sion-review-and-bugs-reporting-thread.304642/
