119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. Abusive
    Cupcake Apr 23, 2015
    Abusive , Apr 23, 2015 :
    How About Wifi Issues ?
    When Im Using Wifi At My Home .. Can't Get Notification Example Is Whatsapp When Phone On Sleep(Lock) .. When I Unlock The Phone .. Flooding Notification Arrive .. Its Really Annoying .. Its Happen Only Using Wifi ... When Using Data(LTE) Nothing Problem At All
    Aznavel and systrace like this.
  2. shrey7
    Jelly Bean Apr 23, 2015
    shrey7 , Apr 23, 2015 :
    FOLLOWING STEPS ONLY IF YOU ARE ON SOME OTHER ROM.. ALL YOUR DATA WILL BE LOST.
    STEP1:
    Download Latest ZIP
    STEP 2:
    Boot to recovery mode. (By holding Press Volume Down + Power button)
    STEP 3:
    NOW DO WIPES: Dalvik cache, Cache, system, data
    STEP 4:
    NOW FLASH DOWNLOADED FILE
    STEP 5:
    AFTER SUCCESSFUL INSTALLATION >> SELECT WIPE CACHE/DALVIK
    STEP 6:
    REBOOT TO SYSTEM.
    edy8 likes this.
  3. lokesh3440
    Honeycomb Apr 23, 2015
    lokesh3440 , Apr 23, 2015 :
    Yes Clean flash is necessary.
  4. manuz
    shrey7 likes this.
  5. matssa
    Ice Cream Sandwich Apr 23, 2015
    matssa , Apr 23, 2015 :
    Because it isn't an update, it replaces the other OTA Update towards Lollipop. It isn't a Incremental Update, otherwise there should be the new features...
    shrey7 likes this.
  6. shrey7
  7. dave_one
    Froyo Apr 23, 2015
    shrey7 likes this.
  8. edy8
    Froyo Apr 23, 2015
    edy8 , Apr 23, 2015 :
    Thank U.
    shrey7 likes this.
  9. rkiwtir
    rkiwtir , Apr 23, 2015 :
    not really.they stopped the pervious lollipop OTA and are rolling this out.
    shrey7 likes this.
  10. jcespi2005
    jcespi2005 , Apr 23, 2015 :
    The new update GSM from Google yesterday seems to correct the issue... So seems no need to fix form CM side.
    bakerbarber and shrey7 like this.
  11. FayeMarkV
    FayeMarkV , Apr 23, 2015 :
    Yes, just flashed the 17L Update via CM Recovery.
    Voice WakeUp has been implemented. A bit similar to the MotoX Moto Voice.
    The recognition processing is not as perfected like GoogleNow, it does work of course. Which brings to mind, you have to disable GoogleNow Voice Search in the Google Settings. Then you will be able to use the Ok OnePlus Wake Up feature.
    Also, the GooglePlayServices has been upgraded to 7.3.29. I have to see if battery life has improved or not.
    CasperTFG and deviantartjr like this.
  12. deviantartjr
    shrey7 likes this.
  13. rkiwtir
    Maybe you have enabled Restrict background data.
  14. shrey7
    deviantartjr likes this.
  15. dave_one
    Froyo Apr 23, 2015
  16. tbamrox
    Gingerbread Apr 23, 2015
    tbamrox , Apr 23, 2015 :
    anybody experiencing voice call interupting issue after enabling "OK ONEPLUS"?as it was the case with google now voice commands
  17. VinceCgto
    VinceCgto , Apr 23, 2015 :
    So, if this is a replacement for the OTA, will I be able to go from YNG1TAS0YL to YNG1TAS17L?
    shrey7 likes this.
  18. sidsid777
    #38
  19. dave_one
    Froyo Apr 23, 2015
  20. VinceCgto
    #40
