119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. aryanhanspal
    Cupcake Apr 24, 2015
    aryanhanspal , Apr 24, 2015 :
    I just flashed cm12s using stock recovery option, now when I go to the developer's options I don't get the option to enable root access. However if I search for root access in the settings I can see the option but when I select it I am again in the Developer Options again with no root access option.
  2. pinoymutt
    Gingerbread Apr 24, 2015
    pinoymutt , Apr 24, 2015 :
    Unlike the open source CM12, COS12 does not have built in root access. I believe it may have something to do with the certification. If you want root on COS12, you'll have to manually root it using SuperSU. (CM11s didn't have it by default either unless you used a kernel with a script or some other way of enabling it).
    DrillSgtOnePlus likes this.
  3. aprince93
    aprince93 , Apr 24, 2015 :
    I had followed the instruction and after installing it is not starting .....Showing Android is upgrading , Staring Apps from 2 hrs ...still I am waiting .....What should I do now ?????
  4. ijstirparo
    Froyo Apr 24, 2015
    ijstirparo , Apr 24, 2015 :
    for those who are not being able to train the voice for the "Ok OnePlus" functionality, try with headphones with mic, worked for me...
  5. aprince93
  6. pinoymutt
    Have you tried wiping your caches in recovery?
  7. aprince93
  8. pinoymutt
    And reflashed the OTA again? If that still doesn't work, either revert to a nandroid backup (if you have one), or you may need to clean flash :(
  9. aprince93
    Now what should I do ???It showing Android is Upgrading and starting Apps from last 2 hrs
  10. aprince93
    Should I stop the running operation ???If yes then How ??procedures plz
  11. aprince93
  12. pinoymutt
    You can manually power off (hold the power button for a few seconds). Then reboot manually into recovery (hold power and down button together) and try clearing caches and/or reflashing the OTA manually.
  13. dtheem
    dtheem , Apr 24, 2015 :
    Something must have been wrong with the original bacon file I downloaded. I deleted it and redownloaded, worked like a charm. Thanks for your help!
  14. aprince93
    This is not the right procedure ...don't wipe cache ......I had deleted cache and it's not staring.....
  15. acetennis
    acetennis , Apr 24, 2015 :
    Has anyone had to manually zip SuperSU? I don't have the option or the folder to root my phone again. Help!
  16. pinoymutt
    Yes, everyone has to manually root COS 12 using SuperSU. It doesn't have built-in root like CM12 open source does.
  17. Orku5
    Eclair Apr 24, 2015
    Orku5 , Apr 24, 2015 :
    I haven't disabled anything - just installed the ROM and cleaned the cache via Android Assistant.
    I had worse battery live with CM12 what came out a week ago as with the latest version. This one seems fine. Need more testing, first impressions seem promising.
  18. acetennis
    Where can I get that SuperSU file?
  19. Elrey311
    Ice Cream Sandwich Apr 24, 2015
    Elrey311 , Apr 24, 2015 :
    It worked for me and many others without any problems. I don't know why it didn't work for you.
  20. Elrey311
