119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. Shyde
    Cupcake Apr 24, 2015
    Shyde , Apr 24, 2015 :
    Tired to wait for Lillipop, thanks for this guide. Downloading now.
  2. York_21
    Gingerbread Apr 24, 2015
    York_21 , Apr 24, 2015 :
    Do a clean flash. Maybe you messed up.
    Clean install is always the solution
  3. Perales
    Eclair Apr 24, 2015
    Perales , Apr 24, 2015 :
    Hello everyone!
    If Install this new cm-12.0-YNG1TAS17L-bacon-signed by TWRP RECOVERY;
    Would I been lost all my apps and data? or what things are going to lost?
    Thanks in advance.
  4. renjiVII
    Honeycomb Apr 24, 2015
    renjiVII , Apr 24, 2015 :
    I was wondering why the update from ota isn't patching at all until I saw this. Downloading the update right now
  5. Elrey311
    Ice Cream Sandwich Apr 24, 2015
    Elrey311 , Apr 24, 2015 :
    I didn't lose anything.
  6. Premierplus
    Eclair Apr 24, 2015
    Premierplus , Apr 24, 2015 :
    Followed the instructions and got it to work. Now running CM12. but there is a small bug on the theme section. The theme sections crashes every time. hopefully that will be fixed soon. Thank you Shrey7.
  7. qwerty-space
    Cupcake Apr 25, 2015
    qwerty-space , Apr 25, 2015 :
    I get an issue where TWRP says there was an error. Here is a screenshot:
    Also, I have an OTA update that is 8.7MB and whenever I tap install and my device reboots into recovery, I select file to flash and reboot. The 8.7MB is still there, all the time.
  8. pinoymutt
    Gingerbread Apr 25, 2015
    pinoymutt , Apr 25, 2015 :
    First thing I'd recommend is getting the latest version of TWRP (2.8.6.0). I believe there may have been some CM12 OTA related fixes in one of the versions between yours and the latest.
  9. qwerty-space
    How do I do that? And will it wipe my phone?
  10. pinoymutt
    Same way you got 2.8.3.0 on your phone the first time (fastboot) -- or if you are rooted, you can download Flashify from the Play Store and use that to flash the latest version from your phone.
    And if you are just updating your recovery, no it won't wipe your phone or mess with your data. Although before you start messing with anything, it's ALWAYS recommended to have a Nandroid backup in case anything goes wrong.
  11. qwerty-space
    Is this the one?
    https://play.google.com/store/apps/details?id=com.cgollner.flashify&hl=en_GB
  12. pinoymutt
    shrey7 likes this.
  13. Gustavo69
    Gustavo69 , Apr 25, 2015 :
    after I followed the steps, it stays in the boot screen, the ne with android and the 1+1 logo, any idea how can i flash it and why i am getting stuck in the same screen, I downgrade to previous update and works..
  14. Gustavo69
    followed the steps and stays in the boot screen, the one with the 1+1 logo and android. at the beginning, any ideas on this?
  15. qwerty-space
  16. IrfanO
    Eclair Apr 25, 2015
    IrfanO , Apr 25, 2015 :
    So all wakelocks for Google play services are still in place? I have disabled all these to see if these have been rectified or not.
  17. qwerty-space
  18. kayemsantosh
    kayemsantosh , Apr 25, 2015 :
  19. qwerty-space
    My phone is broken! flashed the CM12, it bricked my phone, so I restored from a backup from earlier that day. then the cyanogenmod lock screen broke, so I restarted my phone. it worked, but now I can't wake up my screen whenever I lock it.
  20. kayemsantosh
    Is this OK oneplus available for Android 5.1 of cm12.1
