119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. thegios
    Gingerbread Apr 23, 2015
    thegios , Apr 23, 2015 :
    Oh c'mon they haven't fixed the contacts sorting issue: contacts in dialler are still sorted by surname... holy crap!
    #41
  2. donisback
    Cupcake Apr 23, 2015
    donisback , Apr 23, 2015 :
    My phone is rooted and I've teamWin installed on my oneplus.
    I received the OTA, but I'm unable to install it. The phone reboots into TeamWin.. Any help??
    #42
  3. atomic_man
    Jelly Bean Apr 23, 2015
    atomic_man , Apr 23, 2015 :
    Same here, I got the OTA because I initially manually flashed CM12S, but I can't find the update in the file directory because it reboots into TWRP to apply it
    #43
  4. shrey7
    #44
  5. pratik dalvi
    Froyo Apr 23, 2015
    #45
    bakerbarber likes this.
  6. VinceCgto
    VinceCgto , Apr 23, 2015 :
    Only the ones that got the update can confirm it though.
    #46
  7. atomic_man
    I think I got the directory, go to sdcard/Android/com.cyngn.fota/cache
    then flash with TeamWin
    #47
    samueljl likes this.
  8. atomic_man
    #48
    marcofilipa, JRFerreira and nihir like this.
  9. Naki757
    Donut Apr 23, 2015
    Naki757 , Apr 23, 2015 :
    So, anyone knows for sure the new google play version solves the nasty wake lock issues?
    If the updates is mainly for voice one plus i think i'll wait..
    #49
  10. shrey7
    shrey7 , Apr 23, 2015 :
    Yes
    Hope they will fix this issue in next OTA :)
    If you are on rooted phone then you must manually flash the zip.. just follow the instructions, it should alright.
    Really crappy.. not working properly.
    #50
  11. shrey7
    We will hav to wait and see..
    #51
  12. donisback
    #52
  13. eddyh
    eddyh , Apr 23, 2015 :
    E-mail keeped crashing after update.. Had to reboot another time... Now the OK OnePlus wizard is not completed.. Can I restart that? I can not find it in the settings...
    #53
  14. CyborgHA
    Ice Cream Sandwich Apr 23, 2015
    CyborgHA , Apr 23, 2015 :
    it's a full block mode ota with full system image that replace previous version...
    you can install it on cm11s too, this is why it's so big
    #54
    shrey7 likes this.
  15. jcespi2005
    jcespi2005 , Apr 23, 2015 :
    As pointed in first, TWRP users must flash manually...
    No, you can get OTA, but unattended install only works with stock recovery. In fact, the OTA app advices to you about it ;)
    #55
    shrey7 likes this.
  16. 33090601304
    Eclair Apr 23, 2015
    #56
  17. TyroneSpong
    Honeycomb Apr 23, 2015
    TyroneSpong , Apr 23, 2015 :
    Doesnt work here. Rooted OPO with manually installed CM12s. Tried to install it with TWRP and it says "error executing updater binary in zip"
    #57
    deepakaryan1988 likes this.
  18. peteryu
    KitKat Apr 23, 2015
    #58
  19. deviantartjr
    #59
  20. shrey7
    Hmm technically yes.. but if you install OTA then you may loose TWRP and ROOT access as well.
    #60
