119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. olibear
    Froyo Apr 25, 2015
    olibear , Apr 25, 2015 :
    How?
  2. olibear
    Froyo Apr 25, 2015
    Anyone know how to change the battery icon back to a circle? Can't seem to find it.
  3. abaksh
    Eclair Apr 25, 2015
    abaksh , Apr 25, 2015 :
    Just go to Settings>Status bar>Battery status style
    shrey7 and qwerty-space like this.
  4. brettman
    Gingerbread Apr 25, 2015
    shrey7 and abaksh like this.
  5. qwerty-space
    Cupcake Apr 25, 2015
    qwerty-space , Apr 25, 2015 :
    It's worked now. I don't like the look of 5.0 :/ The notification tray and quick settings were better on kitkat
    vikas8395, shrey7 and brettman like this.
  6. brettman
    brettman , Apr 25, 2015 :
    Quick question though. Not sure if this is newb or not, but can I delete a previous version of CM12 or do these updates need to build on top of each other? Thanks.
  7. jonesdt1992
    jonesdt1992 , Apr 25, 2015 :
    Does this fix the battery drain too?
    shrey7 likes this.
  8. ashley27
    Froyo Apr 25, 2015
    ashley27 , Apr 25, 2015 :
    If you've flashed, you can always delete the downloaded files - since it's a manual update that you chose.
    Only OTAs are meant to build on top of each other, since it's automated process.
    shrey7 likes this.
  9. olibear
    Froyo Apr 25, 2015
    I dont even have a status bar option on my settings. See screens.
    shrey7 likes this.
  10. samueljl
    samueljl , Apr 25, 2015 :
    Sir, you're my hero. Thanks for posting this!
    shrey7 likes this.
  11. brettman
    Thanks friend.
    shrey7 likes this.
  12. pompeii2nd
    pompeii2nd , Apr 25, 2015 :
    Im getting slow internet connection via wifi after i flashed COS12.., any suggestiion??
  13. muse1plus
    muse1plus , Apr 25, 2015 :
    Your screenshots do not appear to be of CM12. I suggest you go to "About Phone" and provide your OS version, Android version and Build number.
    olibear likes this.
  14. olibear
    Froyo Apr 25, 2015
    This it?
  15. ned82rt
    Froyo Apr 25, 2015
    ned82rt , Apr 25, 2015 :
    From a rooted TWRP user, these instructions are perfect. Thanks for your work!
    shrey7 and siddug like this.
  16. KeithWalters
    KeithWalters , Apr 25, 2015 :
    My non-oneplus chargers are definitely charging considerably though than they used to. The oneplus charger and cable are fine though
  17. mebaali
    mebaali , Apr 25, 2015 :
    Having to restart modem/router every time to make wifi connection working is not gonna be possible in all situations. Hope there is a quickfix on horizon for this annoying problem.
  18. shrey7
    Jelly Bean Apr 25, 2015
    shrey7 , Apr 25, 2015 :
    Do u still hav same prob?
    Your welcome :)
    So far its good.. im not very impressed with battery. Previous version was working better on my phone.
    Gustavo69 likes this.
  19. shrey7
    Hope they fix this.. my phone is perfectly fine with WiFi though.
    mebaali likes this.
  20. guywong
    Froyo Apr 25, 2015
    guywong , Apr 25, 2015 :
    Do you have the latest version of TWRP, 2.8.6.0?
