119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. shrey7
    Jelly Bean Apr 25, 2015
    shrey7 , Apr 25, 2015 :
    Just disable CM hexo theme.. for some reason i hated it. Use normal theme.. stock.
  2. sanjayy
    Donut Apr 25, 2015
    sanjayy , Apr 25, 2015 :
    received OTA updated morning, i am trying to follow below step but download file not able to trace
    REBOOT INTO RECOVERY
    SELECT >> APPLY UPDATE
    SELECT >> 0
    SELECT >> INTERNAL STORAGE
    SELECT >> cm-12.0-YNG1TAS17L-bacon-signed ( Missing ) help me to get this
    SELECT >> YES
  3. TwiNightx
    Cupcake Apr 25, 2015
    TwiNightx , Apr 25, 2015 :
    Will this update bring back the lock screen dimmer, lock screen long button hold option as I found them to be very useful. The lock screen long button hold allowed me to hold down my home button to switch it to vibrate mode rather than how I have to fidget with the volume button now to make it into silent mode. The lock screen dimmer was also useful since I did not need to drop down the notification bar to change the brightness.
    I have tried looking for these options in Settings but to no success...
  4. shrey7
    Is your phone rooted?
  5. sanjayy
    Donut Apr 25, 2015
    Yes.
    it is showing installation and
    option
  6. sanjayy
    Donut Apr 25, 2015
    when i am going to install, phone goes to Cyanogen recovery mode and below option visible,
    reboot system now
    apply update ->
    wipe data/factory reset
    wipe cache partition
    wipe media
    i selected apply update
    option come
    apply from ADB
    choose from internal storage ->
    then shows
    0/ ->
    legacy/
    obb/
    No file there .
  7. vijendrahs
    Ice Cream Sandwich Apr 25, 2015
    vijendrahs , Apr 25, 2015 :
    check under
    0/Android/data/com.cyngn.fota/cache
  8. sanjayy
    Donut Apr 25, 2015
    Thanks, found this at location 0/Android/data/com.cyngn.fota/cache :)
    system booting now, will it take time ?
    shrey7 likes this.
  9. vijendrahs
    Yes
    shrey7 likes this.
  10. smoothfreeze
    smoothfreeze , Apr 25, 2015 :
    Just updated mine via OTA, no problems :) No manual flash or anything like that. Just have to flash xposed and re-root :)
    shrey7 likes this.
  11. mmnareshbabu
    Gingerbread Apr 25, 2015
  12. shrey7
    Then flash the zip..
  13. vijendrahs
    Flash manually, why to wait and get impatient.
  14. meesee
    meesee , Apr 25, 2015 :
    I got OTA update this morning. After download the file and I went to update it took me to TWRP recovery. Apply Install and went to the file location(Android/data/com.cyngn.fota/cache) and flash and all is great now!!Antutu is nearly 50K - 49734 ! Wow!
    shrey7 likes this.
  15. mmnareshbabu
  16. vijendrahs
    shrey7 likes this.
  17. aryanhanspal
    aryanhanspal , Apr 25, 2015 :
    Then how am I able to see the option to enable root access if I search for it on my phone
  18. tejasna
    tejasna , Apr 25, 2015 :
    Have TWRP(2.8.6.0), Rooted.
    Downloaded the latest file, but it has "fastboot" at the end of the update file name, can I flash the file using TWRP? (Im thinking not!)
  19. jclin777
    jclin777 , Apr 25, 2015 :
    the OTA update size is 598.4 MB... but the zip file given in the links is just 571 MB... is there any reason for the difference? pls clarify
  20. pinoymutt
    pinoymutt , Apr 25, 2015 :
    I think it's probably leftover/holdover code from the open source since they share a similar base. Mine does the same thing -- you can see it in search, but the option doesn't exist in the actual development options. In CM11s, there was a script that would "unlock" the option, but honestly, it's much easier just to flash SuperSU and be done with it.
