119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. jesd98
    Cupcake Apr 25, 2015
    jesd98 , Apr 25, 2015 :
    Im planning on installing this CM12S im currently on CM11S on XNPH05Q
    i saw how to install it, im not rooted or anything like that, my question is if i flash it from recovery will it wipe my phone's data?
    i Mean my apps, accounts and that stuff.
  2. vijendrahs
    Ice Cream Sandwich Apr 25, 2015
    vijendrahs , Apr 25, 2015 :
    No
  3. FabriceGuindon
    Eclair Apr 25, 2015
  4. vijendrahs
    deviantartjr and shrey7 like this.
  5. Jspec007
    Jspec007 , Apr 25, 2015 :
    I was on OG 11s, non-root, stock recovery. I'm not new to rooting, been rooting Cyanogen since my Samsung Captivate etc.. for some weird reason I wanted to wait...BUT I couldn't sit here and wait while reading all these posts..
    Just applied update as per the instructions, easy as pie!
    Phone now reading;
    12.0- YNG1TAS17L
    5.0.2
    3.4.67 -cyanogenmod-g1cbb9b0
    Build04@cyanogenmod #1
    Tue Apr 21 13:54:34 PDT 2015
    Tue Apr 21 13:52:12 PDT 2015
    LRX22G
    So easy! JUST DO IT!
    shrey7 likes this.
  6. sa00044
    Gingerbread Apr 25, 2015
    sa00044 , Apr 25, 2015 :
    My phone model is not recognised when I flash using TWRP. Here is a pic:
  7. shrey7
    Jelly Bean Apr 25, 2015
    shrey7 , Apr 25, 2015 :
    Update TWRP..
    sa00044 likes this.
  8. shrey7
    Enjoy..
    Jspec007 likes this.
  9. sauron.cnp
    Honeycomb Apr 25, 2015
    sauron.cnp , Apr 25, 2015 :
    Your TWRP version is 2.8.0.1 try upgrading to 2.8.6.0 and then apply the CM12s update
    sa00044 and shrey7 like this.
  10. pete3g
    Froyo Apr 25, 2015
    pete3g , Apr 25, 2015 :
    Thanks buddy. If only I had read this before trying to install on a rooted phone ;)
    shrey7 likes this.
  11. rohitmehta89
    Donut Apr 25, 2015
    rohitmehta89 , Apr 25, 2015 :
    Hi. My nfc is always ON and there is no way i can disable it. it's draining battery. what should i do ? it all started after i rooted my phone to install oxygen os and then came back to cyanogen.
  12. sudhakarjha
  13. imraanz
    imraanz , Apr 25, 2015 :
    I'm already on CM 12S YNGTTAS0YL I got the OTA update which is also about 598MB, I have TWRP recover, when touch on Install Update it just reboots into TWRP and dos nothing, is there way to flash this downloaded OTA update?
  14. Jspec007
    Thank you Thank you !! :D:D:D:D
    Settings > More > CHA-CHING!
  15. sudhakarjha
  16. sa00044
  17. sudhakarjha
  18. rohitmehta89
    Donut Apr 25, 2015
    Didnt find any. Post the link please. thanks.
  19. rohitmehta89
    Donut Apr 25, 2015
    I said it's always ON. I am not able to toggle it on and off. :p
  20. SURENDER SINGH
    SURENDER SINGH , Apr 25, 2015 :
    search with ES file explorer and type file name YNG1TAS17L..and copy to download section...
    now please update twrp recovery to latest ,if not it will not flash the latest file...
    after that again zip the super su file (either it asks or not)
    and bingo..
