119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. shrey7
    Jelly Bean Apr 23, 2015
    #61
  2. shrey7
    #62
  3. storm119
    Eclair Apr 23, 2015
    #63
  4. TyroneSpong
    Honeycomb Apr 23, 2015
    #64
  5. Kaizoku
    Ice Cream Sandwich Apr 23, 2015
    #65
    shrey7 likes this.
  6. nirurules
    Gingerbread Apr 23, 2015
    #66
  7. shrey7
    shrey7 , Apr 23, 2015 :
    Is your phone rooted?
    #67
  8. shrey7
    INSTRUCTIONS FOR ROOT USERS:
    (TWRP RECOVERY)
    REBOOT INTO RECOVERY
    INSTALL
    SELECT>> (YOUR DOWNLOADED FILE: cm-12.0-YNG1TAS17L-bacon-signed)
    SWIPE TO FLASH
    SELECT WIPE CACHE/DALVIK
    SELECT REBOOT SYSTEM
    NOTE: AFTER SELECTING REBOOT SYSTEM.. IT MAY PROMPT YOU TO INSTALL SUPER SU (ROOT APP) GO AHEAD AND INSTALL IT.
    #68
    ned82rt and makarand125 like this.
  9. nirurules
    nirurules , Apr 23, 2015 :
    Ya my phone is rooted , I m using multi ROM one with stock rooted n other with cm12.1 official nightlies
    #69
  10. shrey7
    I guess you need flash the zip manually.. im not too sure about MULTI ROM. but since your phone is rooted then you must install it from TWRP.
    #70
  11. TyroneSpong
    TyroneSpong , Apr 23, 2015 :
    I can read bro. It says this file is for A0001. This device is bacon.
    #71
  12. shrey7
    Hmm this device name is A0001 and build name is bacon.. i guess.
    If you are having oneplus then it will work
    #72
  13. shrey7
    Not sure about MULTI ROM.. i think it must be done in TWRP as its rooted.
    #73
  14. b1t
    Cupcake Apr 23, 2015
    b1t , Apr 23, 2015 :
    Update got stuck after reboot on "starting apps". Reset the phone with the power button and next boot was fine.
    #74
    -eth- and shrey7 like this.
  15. nirurules
    Dude can't you get me :) when i click on that download link it starts downloading the whole rom :) I m just asking how to update from previous package of cyanogen is 12 to this current version :) I mean is there any link for downloading just the delta file ..
    #75
  16. lolomjj
    Froyo Apr 23, 2015
    lolomjj , Apr 23, 2015 :
    @shrey7 Hi man,
    Just one question for you. I didn't receive the first CM12 OTA so I'm stil on CM11S, my phone is stock and non-rooted.
    Can I use this flashable zip to update from CM11S to CM12 safely?
    Or is there need for me to update with the first CM12 OTA before?
    Thank you very much ;)
    #76
    shrey7 likes this.
  17. storm119
    Eclair Apr 23, 2015
    #77
  18. shrey7
    NO such file available so far.. you need to update using entire ZIP.
    #78
  19. shrey7
    No problem.. you can go ahead and install latest ZIP it should work fine.
    #79
    lolomjj likes this.
  20. nirurules
    #80
    shrey7 likes this.
