119
CM12S YNG1TAS17L [Installation guide, review, change log]
  1. tim31
    Honeycomb Apr 23, 2015
    tim31 , Apr 23, 2015 :
    o_O Really?!:rolleyes: You're making me feel I want to update straight the way!!!
    KingKaan and shrey7 like this.
  2. nickelodeon
    nickelodeon , Apr 23, 2015 :
    Noob Mode ON
    I have franko kernel will this be a problem? should a flash the stock kernel before updating.
  3. tim31
    Yes it's recommended to always wipe right after you flash even with the original CM recovery
    shrey7 and boggogo like this.
  4. boggogo
    boggogo , Apr 23, 2015 :
    shrey7 and tim31 like this.
  5. tim31
  6. KingKaan
    Froyo Apr 23, 2015
    KingKaan , Apr 23, 2015 :
    it looks like it fixed it but i dont want to be pleased to early. at the moment it is not draining as it was with cm-12.0-YNG1TAS0YL :)
    lets wait and see :D
  7. shrey7
    Jelly Bean Apr 23, 2015
    shrey7 , Apr 23, 2015 :
    Yes.. hope so..
    Why wait for OTA? just flash it.
    Your welcome :)
    YES
    boggogo likes this.
  8. andrelages
    Gingerbread Apr 23, 2015
    andrelages , Apr 23, 2015 :
    Upgrade TWRP to latest version and it should work
    shrey7 likes this.
  9. jhony251
    Froyo Apr 23, 2015
  10. satishkariya
    satishkariya , Apr 23, 2015 :
    hi, i am on 12.0 - YNG1TASOYL version, so will i get OTA or i flash manually .
    this link size you had mentioned is 571 MB.
    DeltaSky likes this.
  11. karl90zgz
    Donut Apr 23, 2015
    deviantartjr and shrey7 like this.
  12. DeltaSky
    Ice Cream Sandwich Apr 23, 2015
    DeltaSky , Apr 23, 2015 :
    Same question here !!!
    satishkariya likes this.
  13. ChefChaudart
    ChefChaudart , Apr 23, 2015 :
    No problem, it will be overridden.
    nickelodeon and shrey7 like this.
  14. shrey7
    YNG1TASOYL did you flash it? if so then which recovery?
  15. shrey7
    Hmm.. so was it not there before?
  16. satishkariya
    i flashed with stock recovery,
    shrey7 likes this.
  17. shrey7
    OK.. so just do the same thing :)
  18. karl90zgz
    Donut Apr 23, 2015
    karl90zgz , Apr 23, 2015 :
    In the first version of 12s I think not (I dind´t find the option).
    shrey7 likes this.
  19. y0ngc6
    Cupcake Apr 23, 2015
    y0ngc6 , Apr 23, 2015 :
    Just flash, the stock rom will overwrite frankco kernel, you can flash fk back later.
  20. biltoad
    biltoad , Apr 23, 2015 :
    does the YNG1TAS17L ota contains userdata_64G.img?
    im trying to flash through fastboot but there is no userdata for the 64G ones, so only 16G is recognized
    can someone share me the file?
    Thanks.:)
