CM12S YNG1TAS17L Issues Thread
  1. Slatter191
    Lollipop Apr 26, 2015
    Slatter191 , Apr 26, 2015 :
    Any link to download 17L...am on CM11S.
  2. Fantomy
    Ice Cream Sandwich Apr 26, 2015
  3. williamhaven
    williamhaven , Apr 26, 2015 :
    When slide status bar to manually adjust screen brightness is on it keeps bumping the screen brightness to maximum whenever I receive a call. This has been happening since i can recall in previous rom's also
  4. alexlam24
    alexlam24 , Apr 26, 2015 :
    This is CM11S all over again. Voice recognition requiring you to scream, camera crashing... Etc
    hamedsbt and joejongue like this.
  5. LidiaFitz
    Gingerbread Apr 26, 2015
  6. joejongue
    joejongue , Apr 26, 2015 :
    There are a few ways, the first is to search the xda forums for a Google play services patch and flash it thru recovery.
    The other involves disabling both the wake and keep awake services from Google play services. This can be done via security > privacy > privacy guard then tap the 3 dots ... and select advanced. Look for Google play services then disable wake and keep awake.
    Warning: this may interfere with certain apps, I do not take responsibility if things do not function properly. In the event they don't, simply re-enable them
  7. kill3r_tadej
    Froyo Apr 26, 2015
    kill3r_tadej , Apr 26, 2015 :
    Cant download mms on stock sms app. Anyone know what to do? And i doesnt have picture of myself on right side...
  8. fbleiker97
    Cupcake Apr 26, 2015
    fbleiker97 , Apr 26, 2015 :
    The only issue I have is that the app drawer never opens up smoothly. It always stutters and just never has that smooth material animation its supposed to.
    prem.kansara likes this.
  9. joejongue
    Damn they must of changed it but I could of sworn I uninstalled mine before the latest cm12 to address the drain issue
  10. joejongue
    Don't have this issue, then again I'm using Apex launcher.
    Have you tried going thru the developers menu and playing with the transition effect speeds?
  11. fbleiker97
    I have yeah, no matter what I do, it stutters. Even if I turn the speeds off
  12. Pranjal.Cmod
    KitKat Apr 26, 2015
    Pranjal.Cmod , Apr 26, 2015 :
    After CM12s YNG1TAS17L update, I've been facing severely reduced surfing speed, however download speeds remain unaffected (not a problem with my internet connection, I checked). Web page rendering and play store rendering times are too long. Google play store ends up showing connection timeout quite frequently. However, once the app page opens up, I get normal speed.
  13. xecqtor
    Honeycomb Apr 26, 2015
    xecqtor , Apr 26, 2015 :
    I installed manual ota today with the instructions for non rooted devices.
    The only issue i have right now which is amazingly annoying is that my wifi has a problem
    Since the update my wifi does take toooo much long to connect succesfully to the router. Dunno why
  14. joejongue
  15. xecqtor
    Before the update i had issues with 5ghz so i had turned it off. So that is not the problem.
  16. Aumakin
    Aumakin , Apr 26, 2015 :
    Is someone seeing this gap in COS12? I noticed it in some CM12 nightlies but it was eventually solved. I was surprised when I saw this bug in COS12, like it was an old nightly.
    It seems like the Google notification (weather) is under an invisible notification, but there's none, and when you touch the screen, it moves to where it should be.
  17. dizzle16
    Jelly Bean Apr 27, 2015
    dizzle16 , Apr 27, 2015 :
  18. kamron
    Froyo Apr 27, 2015
    kamron , Apr 27, 2015 :
    no problem i hope you had a backup
  19. sicilian0
    Gingerbread Apr 27, 2015
    sicilian0 , Apr 27, 2015 :
    And that's coming out when... 2017?
    vrsreekanth likes this.
  20. sicilian0
    My double tap has remained constant with about the same sensitivity.. Once you find the spot that works best always try to hit it there...
    joejongue likes this.
