22
CM13 bugs and annoyances
  1. amartens181
    KitKat Nov 27, 2015
  2. jstepa
    KitKat Nov 27, 2015
    jstepa , Nov 27, 2015 :
    Miscellaneous is not battery drain, found this quote from xda:
    "Miscellaneous is not battery drain.
    Android has preset values which it uses to "predict" the battery drain. If the preset values and the actual battery drain do not match up the battery stats compensate this by showing miscellaneous.
    So basically miscellaneous is the difference between what it thought (preset values) your battery would drain and what it has actually drained"
    You can find that out also by clicking the Miscellaneous in battery...
  3. Taqizadeh
    Cupcake Nov 27, 2015
  4. xeind20
    Donut Nov 28, 2015
    xeind20 , Nov 28, 2015 :
    Can confirm that MMS just won't send. I've tried various APNs and text apps. Chomp. Handcent. Textra.
    None of them send MMS while WiFi is enabled. And even if it's disabled it might take a reboot to get it to send.
  5. doxter
    Cupcake Nov 28, 2015
    doxter , Nov 28, 2015 :
    2811 build,
    Google Maps locate me 50km away in High Accuracy and Device Only mode.
    Battery Saving mode gets it right however.
    cosmic likes this.
  6. shvaboo
  7. bikas
    Ice Cream Sandwich Nov 28, 2015
    bikas , Nov 28, 2015 :
    I'll update the original post then
    jstepa likes this.
  8. bikas
    Taqizadeh likes this.
  9. bikas
    I'll update the op then
  10. bikas
    It works perfectly fine for me
  11. cosmic
    cosmic , Nov 28, 2015 :
    Thanks, have to remember that trick should I hit the problem
  12. larspehrsson
    larspehrsson , Nov 28, 2015 :
    Gps is working in scout, gps status and runtastic, but weatherpro and endomondo does not detect any gps.
    Edit: got endomondo and weatherpro to work. I just had to give them permission to location service manually from app settings. They just did't ask for permission.
  13. Doxin
    Cupcake Nov 29, 2015
    Doxin , Nov 29, 2015 :
    Strange the location issue persists and in last 24h (since 28.11 build), my Google maps place me as far as 50km to 500m randomly from my actual location.
  14. Rowman
    Honeycomb Nov 29, 2015
    Rowman , Nov 29, 2015 :
    Has anyone already installed cm 13 and can report some bugs.
    Rumors:
    - Laserautofocus not supported
    - Fingerprint scanner not working
    - more?
    Is the alert slider working?
  15. gaster
    Lollipop Moderator Nov 29, 2015
    gaster , Nov 29, 2015 :
    As still as it's not official, they may be bugs. Just be patient, cause soon we 'll get an official Cyanogenmod 13 version. Here http://www.androidauthority.com/oneplus-2-cyanogenmod-658573/
    pgidia likes this.
  16. Mr. BG
    Marshmallow Nov 29, 2015
    Mr. BG , Nov 29, 2015 :
    Please report bugs where the should be reported, at Cyanogen or XDA, this fragmented feedback is not working!
  17. artest113
    Eclair Nov 29, 2015
  18. pgidia
    Lollipop Nov 29, 2015
  19. gaster
    #39
    pgidia likes this.
  20. Mukuljj
    Eclair Nov 29, 2015
    Mukuljj , Nov 29, 2015 :
    I have also noticed that the new marshmallow app transition animation does not work on the deafult trebuchet launcher while it does on Google now launcher pretty strang......
    #40
