22
CM13 bugs and annoyances
  1. bikas Ice Cream Sandwich Jan 6, 2016
    bikas, Jan 6, 2016 :
    No it's neither simple, nor definitive. I've tried this solution the moment I got the issue to no avail. It's still a wide open issue.
  2. bikas Ice Cream Sandwich Jan 6, 2016
    You can easily disable Now on Tap to get swipe up feature if that's what you want
  3. bikas Ice Cream Sandwich Jan 6, 2016
    Wrong thread buddy, wrong thread
  4. Junesama Cupcake Jan 6, 2016
    Junesama, Jan 6, 2016 :
    Already fixed the random reboot when i update the gapp with opengapps and the TWRP 2.8.7.0.5 materialised, thx! but the damn gps issure still is the big question...
  5. absolem Eclair Jan 6, 2016
    absolem, Jan 6, 2016 :
    Now on tap is disabled for me, but I still can't use the quick access ring. instead google search pops up after long pressing the home button
  6. absolem Eclair Jan 6, 2016
    Cursor control with volume buttons doesn't work for me. Anyone else?
  7. saar_netzer Donut Jan 6, 2016
    saar_netzer, Jan 6, 2016 :
    I'm using Waze and Google Maps.
    With Google maps the gps is as far as 50KM from my actual point while with Waze it is spot on.
    Can you try Waze and reply to say if this is the same for you?
  8. Metall Cupcake Jan 6, 2016
    Metall, Jan 6, 2016 :
    No reboots from 0105 without reboot fix
    TWRP 2.8.7.0.5
    GPS works fine for me.
  9. Saekkimon Eclair Jan 6, 2016
    Saekkimon, Jan 6, 2016 :
    GPS working for the first time with 20160106. Now everything works good with my device. :)
  10. bikas Ice Cream Sandwich Jan 6, 2016
    OK, I see the issue as well. I think ring is thoroughly removed from marshmallow. I might be wrong though.
  11. bikas Ice Cream Sandwich Jan 6, 2016
    matssa likes this.
  12. amrutprabhu Gingerbread Jan 6, 2016
    amrutprabhu, Jan 6, 2016 :
    Let me try flashing the latest gapp from opengapps and see if this solves my random reboots. Currently i m still facing reboots on 6-1 build also.
    Edit: flashing the latest gapps doesnt solve the random reboots.
  13. matssa Ice Cream Sandwich Jan 6, 2016
    bikas likes this.
  14. Junesama Cupcake Jan 6, 2016
    When I flash the 0106 cm and gapps, the gps somtimes working with gmaps outside but should wait some minutes, somtimes far from 1200KM.
    Always wrong point at home with gmaps.
    I have try the wave that locate is faster and more correctly than gmaps indeed
  15. Metall Cupcake Jan 6, 2016
    Just got a random reboot :(
  16. amrutprabhu Gingerbread Jan 7, 2016
    amrutprabhu, Jan 7, 2016 :
    Me too.. still facing random reboots..:(
  17. amrutprabhu Gingerbread Jan 7, 2016
  18. leonardomgoes Froyo Jan 7, 2016
    leonardomgoes, Jan 7, 2016 :
    Sorry op, I get really irritated with this post.
    Random reboots was not fixed until now for more than 90% of the people.
    Maybe you are lucky with the 20160101 and some combination of not using the phone too much, apps or something. But the majority here are experiencing random reboots.
    So dont put as fixed, your reports are confusing and frustrating the people here. Put as "maybe" or "possibly better" or similar, but not the final word.
    And before you or someone come saying anything, I tried the new TWRP 2.7.0.0.5 mat, updated GAPPS, trying everyday a new nightly, installed the reboot "fix" every update, but nothing...
  19. marconiglio Cupcake Jan 7, 2016
    marconiglio, Jan 7, 2016 :
    Hi everyone
    I've read great part (not all) of the thread.
    I'm a little busy so couldn't spend much time.
    As a matter of fact has been stated on XDA that TWRP 2.8.7.0 can't properly flash the modem.
    Reboots are reported to depend on modem flashing.
    Solutions:
    1. You have to downgrade to 2.8.6.0 (this is the only one) and re-flash the ROM.
    2. you can use materialized TWRP (2.8.7.0.5 stands for a themed TWRP : download the right theme (resolution 720 x 1080), rename it "ui.zip" and put it in a folder named "theme" (create it) in TWRP folder)
    3. you can download CM 13 recovery image and flash it (boot option) and reflash the ROM (mandatory or you will keep booting in CM recovery)
    Each one of these 3 should fix the modem prob.
    My reboots have completely gone since 1 week...
    • No fix for GPS bug continuously locating you alternatively far away and back to the right position, visibile on Google Maps and not on other apps.
    • No fix for poor in-call audio quality on listener side: seems to be a "ok Google" prob and there's a workaround: unchecking "ok Google on all screens" should be able to fix the prob. Alternatively you can edit your build.prop (your phone must be rooted), change persist.audio.fluence.voicecall=true to persist.audio.fluence.voicecall=false & save. After reboot problem will be fixed.
    Hope to be of help...
    Please pardon me if I've written something you already know
  20. saar_netzer Donut Jan 7, 2016
