22
CM13 bugs and annoyances
  1. leonardomgoes Froyo Jan 14, 2016
    leonardomgoes, Jan 14, 2016 :
    Same for me! 0 reboots so far!
    Well bikas... it seems that my propaganda, confusion, lack of care/weight and etc had some reason no?
    Its the first build in a long time that has ZERO random reboots!
    Edit: You are a bit exalted and treat me like a noob, I am only trying to help others here that are confused with this old "fix" and workarounds... Me as these other people are angry of trying so many things and not finding a solution.
    Just relax man! Sorry if I irritated someone here!
  2. leonardomgoes Froyo Jan 14, 2016
    Hi xeind, I am afraid of installing the today build and break the stability... saw some more stuff changing for the bacon in the change logs.
    Let me know how it is running...
  3. xeind20 Donut Jan 15, 2016
    xeind20, Jan 15, 2016 :
    22 hours since the restart from last night's nightly.
    Most stable nightly thus far.
  4. fapergol Donut Jan 15, 2016
    fapergol, Jan 15, 2016 :
    What about restoring and backup on Google? I can't update since they solve this really annoying issue
  5. matssa Ice Cream Sandwich Jan 15, 2016
    matssa, Jan 15, 2016 :
    Still no backup from Google...
    fapergol likes this.
  6. Devrim Cupcake Jan 15, 2016
    Devrim, Jan 15, 2016 :
    Full device encryption does not work on CM13.
    Also TWRP 2.8.7.0 has issues with flashing with CM13, you might get the same problems when updating using TWRP. (or you will need to use a TWRP fork for updating)
  7. Hetune Donut Jan 16, 2016
    Hetune, Jan 16, 2016 :
    Helppp
  8. matssa Ice Cream Sandwich Jan 16, 2016
    matssa, Jan 16, 2016 :
    If you downloaded the app, then it may ne corrupted or incomplete. Download it again and check the file size
  9. smitbhagat Honeycomb Jan 16, 2016
    smitbhagat, Jan 16, 2016 :
    0 reboots...last 48hrs backup....but found a bug in the "Dubsmash" app...the camera is all messed up...any1 facing this bug? Really annoying bug.....
  10. gwie Jelly Bean Jan 16, 2016
    gwie, Jan 16, 2016 :
    The same thing happened in another app I'm using. The weird thing is that the front facing camera works fine in the camera app.
  11. bikas Ice Cream Sandwich Jan 16, 2016
    bikas, Jan 16, 2016 :
    This is because of camera api issue with CM. I've already posted a suggestion on how it didn't affect WhatsApp qr scanner. It is possible that even when what you see is garbled, the final result is correct.
  12. sfinny Donut Jan 16, 2016
    sfinny, Jan 16, 2016 :
    Same for me. 0 reboots since I updated on Wed. I guess there might have been more than 1 issue causing the reboots which got fixed in a recent update.
  13. gwie Jelly Bean Jan 16, 2016
    Weird to read about all these reboot problems. Been using the nightlies for weeks and never had a reboot.
  14. smitbhagat Honeycomb Jan 17, 2016
    smitbhagat, Jan 17, 2016 :
    Y
    Yeah....the final result is ok...
  15. LorenzoM Honeycomb Jan 17, 2016
    LorenzoM, Jan 17, 2016 :
    for me, wifi keeps ever on. I disabled all the voices under Localization --> search.
  16. absolem Eclair Jan 18, 2016
    absolem, Jan 18, 2016 :
    January 17th nightly, following things don't seem to work for me (still):
    -No synchronization with Gmail (notifications don't get pushed anymore, have to refresh manually through the app in order to check for new mails)
    -sadly still no proper GPS fix
  17. absolem Eclair Jan 19, 2016
  18. gwie Jelly Bean Jan 19, 2016
  19. xeind20 Donut Jan 19, 2016
    xeind20, Jan 19, 2016 :
    Latest nightly 0119 might have broken what they fixed.
    Just had my first reboot in almost a week.
  20. matssa Ice Cream Sandwich Jan 19, 2016
    matssa, Jan 19, 2016 :
    I had the same issue for Inbox, and this is caused by Doze. You need to disable the battery optimization for the app (battery menu, 3 dots, optimization).
    absolem likes this.
