22
CM13 bugs and annoyances
  1. sfinny Donut Jan 21, 2016
    sfinny, Jan 21, 2016 :
    I've been having some connectivity issues the last couple of days. While at home with full WiFi connection I suddenly lose connection to the internet and data also. When I'm on data only I have got an apostrophe over my lte signal and it wont connect until I toggle airplane mode on and off. Anyone else getting this? It has been happening maybe since 20160119.
  2. Pietia Cupcake Jan 22, 2016
    Pietia, Jan 22, 2016 :
    When I turn on wifi and then turf off it doesn't really turns off as it's shown in battery stats as online . Is there a fix for it?
  3. xeind20 Donut Jan 23, 2016
    xeind20, Jan 23, 2016 :
    Uptime at 20h. Reboots seem to be gone on 0122.
    Not sure if the issue with 0120 is gone. I didn't really have any reboots with it I don't think.
  4. bikas Ice Cream Sandwich Jan 23, 2016
    bikas, Jan 23, 2016 :
    I actually got few reboots with 22, so decided to investigate. Memory management of CM13 is crap. So, if you've just closed high memory app and tried another one, chances of reboot is too high.
    Few apps are specially culprit in my OS - Sniper Fury (heavy), 9Gag (high caching)
  5. absolem Eclair Jan 24, 2016
    absolem, Jan 24, 2016 :
    Anyone's got an idea where I can dowload older versions of cm13? It seems on the cm website youre only able to donload the latest 5 updates, every other is deleted :(
  6. paultruland Gingerbread Jan 25, 2016
    paultruland, Jan 25, 2016 :
    Anyone else getting really bad battery life on 1/22 and/or 1/23? It's from android system.
  7. oenz Cupcake Jan 25, 2016
    oenz, Jan 25, 2016 :
    I have it too with 1/24 and no sim card on the 1/25.. revert back to 1/24 with poor battery (5hours per day without charging)
  8. bikas Ice Cream Sandwich Jan 25, 2016
    bikas, Jan 25, 2016 :
    I got reboot issues in 22 to 24 builds, which is again fixed in 25.
    Also, with 25, they've added new camera which is awesome
    matssa likes this.
  9. Rai_nA Cupcake Jan 25, 2016
    Rai_nA, Jan 25, 2016 :
    Hi,
    I am using 13.0-20160117 and got problems with the system profiles:
    the lock screen is greyed out in the system profiles but not in the lock screen menu.
    Clearing the credentials in security settings is NOT helping.
    Any ideas?
  10. paultruland Gingerbread Jan 25, 2016
    Update: I'm on 1/25 (dirty flash) and battery life seems to have stabilized. Android system is down to about 4%. Overall the performance has been smooth and no reboots.
  11. BehnanAdam Gingerbread Jan 25, 2016
    BehnanAdam, Jan 25, 2016 :
    same here...no reboots, no battery drain
    and that Snapdragon Camera is awesome...:cool:
    bikas likes this.
  12. xeind20 Donut Jan 26, 2016
    xeind20, Jan 26, 2016 :
    I've got a lot of crashes on this latest build 0125.
    Open camera. Gallery has stopped.
    Open IMDb app. It crashes.
    Happens every time.
  13. bikas Ice Cream Sandwich Jan 26, 2016
    bikas, Jan 26, 2016 :
    IMDb has issues. It seems they're asking for storage permission without explicitly mentioning one. It's not an issue with CM13.
    One thing to note, if you keep clicking these incompatible apps, CM13 will end up in crashes.
  14. xeind20 Donut Jan 26, 2016
    And the gallery crashes?
  15. smitbhagat Honeycomb Jan 26, 2016
    smitbhagat, Jan 26, 2016 :
    26/1 change log has somethig about the gps....can some one confirm whether the gps issue is fixed or not?
  16. bikas Ice Cream Sandwich Jan 26, 2016
    I've no idea about it yet. I'm not using default gallery so can't have any idea
  17. xeind20 Donut Jan 26, 2016
    It's what it says when I try to open the camera.
  18. bikas Ice Cream Sandwich Jan 26, 2016
    My camera works fine. Have you tried clearing all data of camera and gallery app?
  19. filipe.oliveira Cupcake Jan 26, 2016
  20. BehnanAdam Gingerbread Jan 26, 2016
    BehnanAdam, Jan 26, 2016 :
    it has been fixed...
