22
CM13 bugs and annoyances
  1. smitbhagat
    Honeycomb Mar 3, 2016
    smitbhagat , Mar 3, 2016 :
    Nope.....go to location settings>tap on the 3dots on upper right corner>tap scanning and disable Wifi scaning
    All the best :D
  2. brettw994
    Eclair Mar 3, 2016
  3. paultruland
    Gingerbread Mar 3, 2016
    paultruland , Mar 3, 2016 :
    Same here and still have the problem. Turning on Privacy Guard and changing this for specific apps was suggested to me, but doesn't seem to be helping.
  4. brettw994
    Eclair Mar 3, 2016
    brettw994 , Mar 3, 2016 :
    I have had WiFi off all day long and it some how still is taking up 11% which is higher then screen on time.
    I attached pics showing WiFi not active all day.
  5. paultruland
    Gingerbread Mar 4, 2016
    paultruland , Mar 4, 2016 :
    Did a clean install of the 3/3 nightly last evening along with lightning kernel, wifi drain seems to have stopped (wifi scanning disabled).
  6. smitbhagat
    Honeycomb Mar 5, 2016
  7. sans001
    Cupcake Mar 17, 2016
    sans001 , Mar 17, 2016 :
    Unexpected crashing of clock, when widget is added to home screen .
    Ive installed cm13 snapshot ..
    Is anyone experiencing the same issue ?
  8. amitganguli123
  9. daniga74
    Jelly Bean Mar 17, 2016
    daniga74 , Mar 17, 2016 :
    which twrp version did you use?
    use 2.8.6.0 or 3.0.0.1
  10. hamzie
    Eclair Mar 18, 2016
    hamzie , Mar 18, 2016 :
    manually put in the apn
  11. sans001
    Cupcake Mar 18, 2016
  12. Zaabuu
    Zaabuu , Mar 18, 2016 :
    I don't know if this goes here but I just got the message on my OPO to update to CM13 after downloading, installing and updating I got a message: "Unfortunately, Google Play Services has stopped"
    And another warning message saying like I need to update it, however, the message keep pooping up and it's very annoying since you can't do anything
  13. killerbee13
    Jelly Bean Mar 18, 2016
    killerbee13 , Mar 18, 2016 :
    Download and install gapps for android marsmallow ?
    http://opengapps.org/
    Best way is to go into recovery
    Wype system/cache
    install cm13
    install gapps
    Wipe cache dalvik
    reboot
  14. nikol_oza
    Gingerbread Mar 19, 2016
    nikol_oza , Mar 19, 2016 :
    only 1 bug found on screen navigation keys cover some app menus and cant use normal other is good
  15. smitbhagat
    Honeycomb Mar 24, 2016
    smitbhagat , Mar 24, 2016 :
    Aaand...the random reboots are back with the 3.23 build.. anyone else facing this?
  16. cnl
    cnl , Mar 24, 2016 :
    DO NOT UPDATE TO NEW 23 BUILD! PHONE REBOOTS DURING INCOMING CALLS!
    smitbhagat likes this.
  17. smitbhagat
    Bro...it reboots randomly
    cnl likes this.
  18. cnl
    Im not your bro pal hahaha
    no but srsly my phone reboots just when someone is calling me...
    During normal use i dont get reboots
  19. brettw994
    Eclair Mar 25, 2016
    brettw994 , Mar 25, 2016 :
    I almost updated last night and glad I didn't now. Even though I can always revert back to previous
  20. acuervofm
    Cupcake Mar 25, 2016
    acuervofm , Mar 25, 2016 :
    Hi everyone,
    I have a serious problem and haven't been able to find information nor solutions. My Opo keeps dropping calls, incoming and outgoing making it impossible to have a conversation.
    I had cm12.1 and received an Ota update to cm13 6.0.1 snapshot 20160316 and did it. This caused gapps to show a Google Play Sevices error so I reflashed cm13 and opengapps 6.0. I used Twrp 3.0.0.1 to wipe and install but was not getting any results, it seemed like it wasn't flashing so the play services kept crashing. I did a factory data wipe in Twrp and everything looked good until I started making phone calls, instant dropped calls, incoming and outgoing.
    I've been trying to replicate the dropping of calls but haven't found anything. The only thing noticeable is that if I move the faster the calls drop. In a car it's very difficult to have a call.
    Can anyone please offer some advice or ideas. Dropped calls is a pain and if I can't find a solution I'll have to go back to 12.1.
    Thanks
    Andrés Cuervo
