22
CM13 bugs and annoyances
  1. rahulreddyg25 Cupcake Dec 4, 2015
    rahulreddyg25, Dec 4, 2015 :
    Is anyone facing call quality issues ... People on other side of call cannot hear my voice clearly..am on dec 2nd build
  2. bikas Ice Cream Sandwich Dec 4, 2015
    bikas, Dec 4, 2015 :
    First of stop shouting!
    Now, when you say no bugs, can you also be generous enough to send screenshots across? We'll have bugs and some of them are even in CM issue registry. I'd love to see how it's working on yours.
    jstepa likes this.
  3. rameshk1994 Cupcake Dec 4, 2015
    rameshk1994, Dec 4, 2015 :
    I don't think that's the problem... Does not occur with all apps... Chrome for instance, in landscape mode does not have the status bar over the nav bar, whereas most of the other apps do...
    matssa likes this.
  4. Deactivated User Dec 4, 2015
    matssa likes this.
  5. CasperTFG KitKat Dec 4, 2015
    CasperTFG, Dec 4, 2015 :
    Let's hope and pray that COS 13 allows people on the other end of your phone conversation to actually hear you instead of a static mess.
  6. bikas Ice Cream Sandwich Dec 4, 2015
    COS team will not listen much. I hope CM team keep on improving, these guys listen.
  7. matssa Ice Cream Sandwich Dec 4, 2015
    matssa, Dec 4, 2015 :
    Sometimes the modem isn't flashed correctly, which can repair the different data / wifi issues that we can have. The official TWRP 2.8.7.0 can't flash the modem, but the materialized one (custom) can (older versions can as well).
  8. venkatplusone Donut Dec 5, 2015
    venkatplusone, Dec 5, 2015 :
    Dirty flash couldn't find my sim card. Did a clean flash. Now I couldn't find screen colour calibration like changing the saturation, hue etc. Screen looks totally washed out... Is this missing in CM13 ?
  9. matssa Ice Cream Sandwich Dec 5, 2015
    matssa, Dec 5, 2015 :
    No it's there ;) strange that you have a bad screen...don't have anything from my side.
  10. venkatplusone Donut Dec 5, 2015
    I am actually referring to the below screenshot.. Since i have tweaked it my CM12.1 , the current screen colour drives me crazy ... So ur saying this setting is present in CM13 ? If yes can u pls guide me ?
  11. jstepa KitKat Dec 5, 2015
    jstepa, Dec 5, 2015 :
    I have not found this setting either, somebody suggested this
    Works at least in Sultan's MM...
  12. venkatplusone Donut Dec 5, 2015
    Thanks , but its not supported in CM13 :mad: ...
  13. menisasson Eclair Dec 5, 2015
    menisasson, Dec 5, 2015 :
    Have same call quality issue, only when talking through phone earpiece. On speaker or BT I don't have this problem
  14. matssa Ice Cream Sandwich Dec 5, 2015
    Ah true there still isn't this feature, you can only choose the different color % in Live Display...
  15. Mukuljj Eclair Dec 5, 2015
    Mukuljj, Dec 5, 2015 :
    Y
    yeah I'm also missing the vibrant color mode
    But it is what it is and I think it will be added in the future builds and since Dec 1st nightly I have noticed the colors to be better than before... I also like this new horizontal scrolling notification drawer makes life easy
  16. mkoelsch Gingerbread Dec 5, 2015
  17. artest113 Eclair Dec 5, 2015
    artest113, Dec 5, 2015 :
    hey guys, ever since the 4th December build, I noticed that the standby had gotten worse terribly, it turns out that when I looked into the battery stats, there are several apps that shows usage in mobile radio active and the timer is getting higher and higher, I certainly think this does not exist in the build older than 4th Dec
  18. CMYK Honeycomb Dec 5, 2015
    CMYK, Dec 5, 2015 :
    Cannot "forget" saved (Wi-Fi) networks.
    You can remove it, but when you view saved networks again, it will re-appear.
    MarmiteX1 likes this.
  19. MarmiteX1 Gingerbread Dec 5, 2015
    MarmiteX1, Dec 5, 2015 :
    Can you provide a screenshot so people can assist? Thanks.
  20. NeroNemesis25 Cupcake Dec 5, 2015
    NeroNemesis25, Dec 5, 2015 :
    damn, good work, Im not sure why people would willingly subject themselves to such a buggy firmware
