2
ColorOS 12(Android 12) via OnePlus 8T
  1. Last edited by a moderator: Jan 21, 2022
    therahuldahiya and fpkk like this.
  2. Aaron2017
    General Support Expert Award 2021 Jan 17, 2022
  3. Aaron2017
    Aaron2017 , Jan 17, 2022 :
    That's not my point. It's beta yes, but i assume you're software version now is OxygenOS 11 and not ColorOS 11?
    ColorOS is meant for China users only.
    OxygenOS is meant for global/India/EU
    Gor., omarmawal, Caomhin and 3 others like this.
  4. #6
    Aaron2017 likes this.
  5. Aaron2017
    You're welcome 👍
    Although i can't know this for sure of course, but usually when a ColorOS update is released for China users, it doesn't take that long before one is released for OxygenOS too. So maybe it won't be long before beta for OxygenOS 12 kicks off too. But like i said, that's an assumption, i don't know anything for sure
  6. Aaron2017
  7. X1602573027191
    Cupcake Mar 14, 2022
  8. Z1648840193092
    Cupcake Apr 1, 2022
    Z1648840193092 , Apr 1, 2022 :
    I have a question sir, 8 have a OnePlus 8t kb2000 model number kb05ba
    If I install the beta version of oxygenos 12 will I receive after that the official Ota update of the global oxygen is version ?!
  9. Aaron2017
    General Support Expert Award 2021 Apr 1, 2022
    Aaron2017 , Apr 1, 2022 :
    Yes, if you install the global beta version you will get the global stable version. But, you can install the stable version of Oxygen OS 12 instead, as that already has been released for the global region.
    Gor. and Bobbie63 like this.
  10. Z1648840193092
    Cupcake Apr 2, 2022
    Z1648840193092 , Apr 2, 2022 :
    Am not from China am from north Africa can you please send me de link to the global stable version please I've found only for the Indian and the European versions Can I install one of them or there's a special on for my model and can you send me a reliable link please thanks sir
  11. Aaron2017
    General Support Expert Award 2021 Apr 2, 2022
    Aaron2017 , Apr 2, 2022 :
    You can download an app called Oxygen updater from the play store, that app will automatically offer you the correct version (based on your build number in Oxygen OS 11) and, once tje update is downloaded, place it in the correct place, so all you have to do is go to the local upgrade and install it. It is a third party app non related to OnePlus, but it takes the update file directly from OnePlus' servers so it is the same on as the one you would normally get OTA.
    Vachtang_Basilashvili and Gor. like this.
  12. Z1648840193092
    Cupcake Apr 2, 2022
    Thanks I have the oxygen updater, the problem is that the last update I've downloaded crushed my phone and I was forced to do a wipe cache and reset Data Factory to recover the os.
    That's why now am asking about doing it manually and am used to flash and upgrade others phone just it's my first time in OnePlus that's why am asking, and thank you very much sir for your patience and kindness.
  13. Z1648840193092
    Cupcake Apr 2, 2022
    The problem is that oxygen updater insist on attributing me the European versions not the Chinese kb2000
  14. Z1648840193092
    Cupcake Apr 2, 2022
  15. Aaron2017
    Yes, that's because you have the EU ROM of Oxygen OS 11 installed in your phone. You have a China variant with the EU ROM installed. China variants run on Color OS in China, not Oxygen OS. There is no EU version of Oxygen OS 12 yet, so if you want this version now, you'll have to either flash the global version or the India version
    Z1648840193092 likes this.
  16. Z1648840193092
    Cupcake Apr 2, 2022
