30
Combined Battery Drain Issues Thread
  1. srinivasan_v
    Froyo Apr 9, 2015
    #41
    Niels_Andersen likes this.
  2. miizoo
    Gingerbread Apr 9, 2015
    miizoo , Apr 9, 2015 :
    Thank you. All of this makes sense, Fix#5 did the trick for me on Oxygen OS. I'm getting around 6-7 sot with heavy usage on LTE.
    #42
  3. Niels_Andersen
    KitKat Apr 9, 2015
    Niels_Andersen , Apr 9, 2015 :
    Glad to hear that it works for Oxygen, too, so I can add this info to the intro.
    #43
  4. joeleodabomb
    joeleodabomb , Apr 9, 2015 :
    I just installed Oxygenos the other day, and since then, Google play services has been keeping my phone awake constantly. Anyone else with this issue? Anyone know how to fix it? Thanks.
    #44
  5. DaxNagtegaal
    Marshmallow Apr 9, 2015
    DaxNagtegaal , Apr 9, 2015 :
    "I can't think of anything better than IB4L, so here's a smiley :)" - from OnePlus @Neth
    This is the millionth thread about the google services bug go search
    #45
  6. Jasmohit
    Jelly Bean Apr 9, 2015
    Jasmohit , Apr 9, 2015 :
    #46
    zulf91 likes this.
  7. gringoboy
    Lollipop Apr 9, 2015
    gringoboy , Apr 9, 2015 :
    I'm not on Oxygen, but read this.
    #47
  8. DanDuke641
    Honeycomb Apr 9, 2015
    #48
    vokzzi likes this.
  9. Takendown
    Jelly Bean Apr 10, 2015
    Takendown , Apr 10, 2015 :
    To simply fix it, uninstall Google Play Services. To do this, disable it. You'll then be asked to access device administrator to do it (it's simple, just follow the on screen instructions). Once uninstalled, all you need to do is install it again. After installation, make sure your GPS is set to Battery Saver.
    Many have found this fix to work, and I gave it a try only yesterday. I can confirm it is working, as Google Play Services no longer shows up under battery.
    #49
    FalconFX likes this.
  10. Android the Greek
    #50
    joaon likes this.
  11. Android the Greek
    Android the Greek , Apr 10, 2015 :
    Wow this was a good idea
    #51
  12. Takendown
    Is it working for you as it is for me?
    #52
  13. anuj.jain936
    Gingerbread Apr 10, 2015
    #53
    Takendown likes this.
  14. Kapitan Nemo
    Lollipop Apr 10, 2015
    #54
  15. Android the Greek
    Well first I learned yesterday a lot of my battery issue was from sounds search sync error. When I disabled play services and reinstalled that option disappeared. Lets see how it goea
    #55
  16. Takendown
    I'm glad to hear it! Battery problems disappeared for me. Let me know how it goes, indefinitely!
    #56
  17. AndyLao1031
    Ice Cream Sandwich Apr 10, 2015
    AndyLao1031 , Apr 10, 2015 :
    edit
    install xposed get app ops
    disable keep awake and wake up for g play service
    #57
  18. Takendown
    Not doubting that your method works, but not everyone wants to install the Xposed mod.
    #58
  19. Jeffrey98
    #59
    TeamValor91 likes this.
  20. Jeffrey98
    #60
