Company Name Display on Incoming Calls via OnePlus 7T
  1. karthikeyans1977
    Gingerbread Jul 1, 2020
    karthikeyans1977 , via OnePlus 7T , Jul 1, 2020 :
    While receiving incoming calls, the company name from stored contacts (when you store name, no. and company in respective fields) is not displaying.That feature is available on OP 5 with the latest update. When will it come to OP 7T? Been asking for this feature for nore than three years now and in between switched to iPhone just for this and returned back to OP. Glad to see it is being included as a feature for OP 5 users but will be great if it can be made available for everyone else as well.
  2. the_o2
    User of the Year 2018 Jul 1, 2020
    the_o2 , Jul 1, 2020 :
    that is India specific, for that you have to use Indian Oxygen OS as well as only Indian SIM and
    You have accept the terms for the caller identification thing.
    BTW press and hold the dailer app
    Go to settings
    Caller identification
    Make sure both the option is enabled there.
    karthikeyans1977 likes this.
  3. karthikeyans1977
    I am using the India specific OS and also the setting you had suggested is enabled. I have also checked couple of my friends who are using OP 7T and OP 6 but its not available on their phones too.
  4. the_o2
    Clear the storage data of the dialer app and restart your phone once and check.
  5. karthikeyans1977
    Will try doing that now and update. Is it working for you? Which model are you using? Thx for your help and really appreciate. Will get back shortly
  6. karthikeyans1977
    trued but its still not working!
  7. karthikeyans1977
    the_o2 likes this.
  8. the_o2
    User of the Year 2018 Jul 2, 2020
    the_o2 , Jul 2, 2020 :
    Do you have a Jio SIM.
  9. karthikeyans1977
    Gingerbread Jul 2, 2020
  10. the_o2
    Disable the Airtel SIM, again delete the storage of the dialer app reboot and open the app and give the permission if it asked and check.
  11. karthikeyans1977
    karthikeyans1977 , via OnePlus 7T , Jul 2, 2020 :
    the_o2
    Disable the Airtel SIM, again delete the storage of the dialer app reboot and open the app and give the permission if it asked and check.​
    Tried but no luck. Is it working in any other OP 7T model or any other model apart from OP 5?
  12. the_o2
    I will check and tell.
  13. karthikeyans1977
  14. the_o2
  15. the_o2
    Just checked on 7TPro based on Oxygen OS 10.3.3 it also have here the screenshot
  16. karthikeyans1977
    This is for num ers thats not stored in your contact. The network tries to identify to label it as Spam or any other organisation names directly from network. But the company name for stored contacts is something thats not getting displayed in any other OP phones apart from OP 5
  17. the_o2
    User of the Year 2018 Jul 3, 2020
    the_o2 , Jul 3, 2020 :
    Can you post any screenshot, not getting it.
  18. karthikeyans1977
    Gingerbread Jul 3, 2020
    karthikeyans1977 , via OnePlus 7T , Jul 3, 2020 :
    the first one is how it works in OP 5 where the company name is shown. The second is same setting that you had shown which is available on my OP 7t as well. I don't think that feature has been made available to all models. As of now it's only available for OP 5.
    the_o2
  19. the_o2
    The sport thing which is written below the name?
  20. karthikeyans1977
    Gingerbread Jul 5, 2020
